![]() | Home > Maintenance & Mods (L322) > TDV8 4.4 Belt Help Needed |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35805 ![]() ![]() |
have a read of this 'how to' from our wiki, it might help identify your problem,
Dstew Member Since: 26 Dec 2020 Location: Kent Posts: 44 ![]() ![]() |
Have been through the wiki. Don't understand why a tensioner change should cause belt failure after 5 minutes. Then another new belt failure immediately. Any other ideas? |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 547 ![]() ![]() |
If you can rule out the obvious first, such as pulley damage, pulley mis-alignment, or simply catching on something.
Solved the problem. Indy has replaced the tensioner I fitted with a genuine one and it’s now fine.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3555 ![]() ![]() ![]() |
I bought something from John Craddock listed as, and shown in pic as genuine and it came as Britpart.
I’ve sent them the photo and will follow it up with a report from the Indy.
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
i just had all of mine done and the tension pully that came off after 115k looked in better shape than that.
Same here. The pulley on the old one with 120k looked fine. But the the belt was running right up to the edge so needed changing. |
I'm not a Britpart fan, some of there stuff is ok and I've used bits & bobs on Defender's and RR Classics in the past, but wouldn't use anything from them on either of my L322's.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16398 ![]() ![]() ![]() |
Remove the B and insert as S!
Brilliant! |
Engine all now running fine with new genuine tensioner. Now in discussion with John Craddock over their liability for selling such shoddy parts. Interesting to note that they have now changed the web page for this item and it no longer shows a picture of a genuine part box. |
