Home > Technical (L322) > Turbo Actuator, Turbo boost control solenoid |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
hey model and engine would be good so we can help 2012 Vogue 4.4 TDV8 - Current
20th Feb 2021 3:19pm |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1194 |
And perhaps a lot more on the background as to why would help, which all are happy to do. Cheers
20th Feb 2021 3:29pm |
Ikorodu Member Since: 19 Feb 2021 Location: Kent Posts: 5 |
Oops!!
20th Feb 2021 3:55pm |
I'll happily go down in flames!!!!
20th Feb 2021 4:30pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2314 |
Was just the belt changed or were the pulleys also changed? Initial squeaking or squealing suggests dry pulley bearings.
20th Feb 2021 8:52pm |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 663 |
There is no chassis to lift the body off unless you have a Sport [think I'm correct?].
21st Feb 2021 10:51am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3689 |
http://www.fullfatrr.com/gallery/albums/us..._TOPIx.pdf
21st Feb 2021 11:51am |
Thanks for the help/tips Guys
21st Feb 2021 4:17pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
Are you in restricted performance?
21st Feb 2021 5:55pm |
Lubricant isn't applied to the pulleys which use a so-called sealed bearing. |
21st Feb 2021 11:21pm |
@GGDR thanks, will check them all and share my findings
22nd Feb 2021 12:58am |
Be ready to spray water onto the belt to see if the noise stops. If it stops then the belt is very likely the culprit. |
23rd Feb 2021 4:57am |
Another way to prove or eliminate 'belt squeal' is do what my Indy did........dived into his tool box and came out with a container of...........Johnsons Baby powder! [other similar makes are available]. He squirted this on the belt, fired her up & quietness. You can always buy expensive 'anti squeal' spray but this stuff absorbs any moisture [cause of the squeal] and after cleaning off any powder, all sorted! 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
23rd Feb 2021 9:32am |
dennij Member Since: 24 Feb 2019 Location: Up North Posts: 450 |
I bet it smelt nice too 2011 TDV8 Vogue SE |
23rd Feb 2021 9:34am |
