Home > Technical (L322) > Turbo Actuator, Turbo boost control solenoid
Ikorodu
United Kingdom 2012 Range Rover Vogue 4.4 V8 Santorini Black
Hi Folks
Does anyone have any ideas on how much work the following is:
Turbo actuator (replace)
Turbo boost control solenoid (remove, strip & rebuild)
- Approximately how many hours?
- Will this require lifting the chassis?
- Is this a 1 man or 2 man job?
Thanks! 2012 Vogue 4.4 TDV8 Santorini Black - Current
Sorry! there's no going back once you've driven a V8
Post #584565 20th Feb 2021 3:12pm
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
hey model and engine would be good so we can help 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #584566 20th Feb 2021 3:19pm
rjff
And perhaps a lot more on the background as to why would help, which all are happy to do. Thumbs Up Cheers
Richard
Gap IIDBT
Post #584568 20th Feb 2021 3:29pm
Ikorodu
Oops!!
Smile
It's a 2012 Vogue 4.4 TDV8
The why
I'm getting a Restricted Performance warning after the car is driven for between 25 - 35 mins
Issue 1
Diagnostics has brought up the following code: PO046-77
Turbo/supercharger boost control
Solenoid - Circuit range/performance
Issue 2
On starting the engine (only when started from cold), I get a squeaking, squealing noise similar to a misaligned belt. (the belt was changed recently so it's not that)
Issue 3
On switching off, after being driven for over 20 mins, a clicking noise can be heard for about 5 mins and then it stops
(turbo switching back and forth on actuator?)
Generally speaking though, she drives well, does not smoke, and prior to Limp mode, does not lose any power.
I am prepping myself for the dreaded chat with my mechanic Shocked 2012 Vogue 4.4 TDV8 Santorini Black - Current
Post #584575 20th Feb 2021 3:55pm
rjff
I'll happily go down in flames!!!!
On item 3 stick your head under the bonnet and tell us where you think the noise is coming from. Front-ish central? Pop the engine cover off and listen/feel if there's anything about. May help.
Others with more sense will be along. Cheers
Richard
Gap IIDBT
Post #584582 20th Feb 2021 4:30pm
GraemeS
Australia
Was just the belt changed or were the pulleys also changed? Initial squeaking or squealing suggests dry pulley bearings.
Depending on when your engine was built, the secondary air change-over valve may be the early version that can become sticky. Lots of threads on here about spotting it to determine if an early one or not.
I would ignore any noises after switch-off as they will be either the EGR valve being exercised trying to keep it clean for clicking or injectors being given ultrasonic cleaning for the high pitched squeal.
Post #584624 20th Feb 2021 8:52pm
Fox889
There is no chassis to lift the body off unless you have a Sport [think I'm correct?].
I have a '12 plate Westminster & when I hit 2750-3000rpm the dreaded red 'restriction' flashed up, stopped the car, locked her up & came back 5 mins later, no 'restricted performance'. Cut a long story short, the second turbo is part of the sequential system & don't come out to play until you hit close to 3000rpm. My Indy stripped & cleaned the actuator & she's perfect now.
I would go with GraemesS thought on the pulley being dry & cold on start up.
When you say "after 25-35mins" is that normal driving? Up hills when you're asking the old girl to work for her keep? High speed-low speed? If so, could be the old 'donut' hoses need replacing with silicone ones?
Hope this helps. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #584679 21st Feb 2021 10:51am
Baltic Blue
http://www.fullfatrr.com/gallery/albums/us..._TOPIx.pdf
Mine was exactly the same when I bought it in 2015, MD fixed it by the this bulletin.
Post #584682 21st Feb 2021 11:51am
Ikorodu
Thanks for the help/tips Guys
@rjff - Noise seems to be coming from the driver's side
@GraemeS - Primary and secondary belts, tensioner, pullies, pulley fan, and bracket were all changed 5 months ago.
Saying that, perhaps they did not apply enough lubricant? - I will be very upset if this is the problem Sad
@Fox889 - Take your point on suggested - Actuator strip & clean
"after 25-35mins" - this is me driving 70 mph on the motorway and then 25-35 mph within town
@Baltic blue - Thanks for this.
My big worry is the PO046-77
Solenoid - Circuit range/performance 2012 Vogue 4.4 TDV8 Santorini Black - Current
Post #584699 21st Feb 2021 4:17pm
GGDR
Are you in restricted performance?
90% of issues with the 4.4TDV8 are boost leaks from pipework.
I had an actuator error code (can't remember if it was the same as yours) and in the end it was false.
Guess what it was..?
It was a boost leak.
So if you're in restricted performance then's I'd have a good look at your hoses. Search "donut hoses"
. Cheers, Greg
Post #584714 21st Feb 2021 5:55pm
GraemeS
Australia
Lubricant isn't applied to the pulleys which use a so-called sealed bearing.
Post #584772 21st Feb 2021 11:21pm
Ikorodu
@GGDR thanks, will check them all and share my findings
@GraemeS - hmmm 360-degree turn Smile - so if it's not pulleys needing lubrication, what could it be...?
A luta continua! 2012 Vogue 4.4 TDV8 Santorini Black - Current
Post #584779 22nd Feb 2021 12:58am
GraemeS
Australia
Be ready to spray water onto the belt to see if the noise stops. If it stops then the belt is very likely the culprit.
Post #584884 23rd Feb 2021 4:57am
Fox889
Another way to prove or eliminate 'belt squeal' is do what my Indy did........dived into his tool box and came out with a container of...........Johnsons Baby powder! [other similar makes are available]. He squirted this on the belt, fired her up & quietness. You can always buy expensive 'anti squeal' spray but this stuff absorbs any moisture [cause of the squeal] and after cleaning off any powder, all sorted! Wink 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
1973 Honda CB250 K4
Post #584907 23rd Feb 2021 9:32am
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
I bet it smelt nice too Very Happy 2011 TDV8 Vogue SE
Post #584909 23rd Feb 2021 9:34am
