Home > Technical (L322) > Hood not opening.
umitbat
Turkey 2010 Range Rover HSE TDV8 Atacama Sand
Hood not opening.
Hi
My cable was broken and I changed from Ralux parts.
But it is gone quickly.
This time I cannot open even by pulling the stripped cable manually.
It does not move a bit at all.
So inside connection is gone too.
I cannot find the opening from front grill as some guys could open from there.
I think 2010 models don't have any opening there.
Any ideas???
 2010 3.6tdv8 155k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #584928 23rd Feb 2021 10:02am
Sam
Assuming yours is left hand drive and the bonnet release lever is on the left (Drivers side), Jack up the same side front wheel, remove the fastenings and pull down the plastic wheel arch liner, then reach up with your hand to the area around the headlamp. You should be able to feel the release cable, or what's left of it. As long as it hasn't snapped at the bonnet catch end you should be able to give the cable a tug and it will then open.
Good luck.
Post #584943 23rd Feb 2021 11:36am
umitbat
Thanks
will try!! 2010 3.6tdv8 155k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #584949 23rd Feb 2021 1:36pm
Site Copyright © 2006-2021 Futuranet Ltd & Martin Lewis
