![]() | Home > In Car Electronics (L322) > DSP Amp Failing Splice them? |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3982 ![]() ![]() ![]() |
I had similar symptoms to you some years ago, traced it to bad plug connections on the top of the dsp. Cleaned the plugs up and did a bit of fiddling, all speakers came back on and have been fine ever since.
Darryl72 Member Since: 25 Oct 2016 Location: East Sussex Posts: 62 ![]() ![]() ![]() |
Ive wiggled , tried electric cleaner and tooth brushes with no result almost wish it was the pins I could a least bypass them, thanks for your reply though. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7991 ![]() ![]() ![]() |
The amp is actually the BM54 radio unit, the DSP is simply an active crossover.
Ok. I don't really see why you can't just do way with the dsp altogether and re arrange the speaker output wires from the bm54 radio to connect with the various speaker wires that normally output from the dsp. The bm54 radio is in fact the amplifier, the dsp is a sound processor. Never had the need to do it myself but I have a suspicion others might have who could give you further advice. |
Interesting info, DSP is showing and sounds like its working just through the left front side only, I can adjust the output of the DSP. |
I hate to say this but you have checked the balance and fader settings? Nobody been tampering by any chance. |
Because the system is an active system, not a passive one, so the crossovers are powered by the 12v feed in the DSP unit.
lol yep balance fader are ok, ive been using that today to turn down the left to hear from the rear if wiggles/spray make a difference! Thanks guys thats a wealth of knowledge for me to proceed tomorrow in the light.
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2246 ![]() ![]() ![]() |
If you can confirm it’s the bm54 unit not the dsp - which is probably likely those bm54 were crap - get yourself a decent Android carplay/Android auto unit for £200 well worth the upgrade then get a resler interface and ibus app and you can keep all the dsp and onboard computer things. Current stable:
