![]() | Home > Maintenance & Mods (L405) > Handbrake stuck on |
| Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 714
On the L322, there's an a mechanical Emergency Release cable in the RHS compartment in the boot. Just Pull it (Hard) & it releases the mechanism.
| Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2721
I’ll need to check the handbook, cheers . Just found a thread from a couple of months back which points me in the right direction. |
| knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 782
It's under the cupholders in the front. There is a red strap which needs a good, hard tug to release it. Hope this helps.
| diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 491
Have you tried putting it into service mode to see if it releases it? I’m sure there is no mechanical release on these as the handbrake mechanism is built into the calliper, so no cables going to it. |
Yup tried that mate, does sweet fa , have checked the handbook, no manual release either. Garage is less than a mile away so will leave her in the drive until I get get it looked at. |
| Fifth Horseman Member Since: 04 Jul 2016 Location: Lanarkshire Posts: 236
Only way to manually release the parking brake is to remove the actuator from the calliper and operate the mechanism (clockwise rotation to release) in the calliper.
Thanks mate |
For reference , part number is LR036573, not handed . Get them on the bay from £29 (china) , also a motor factor down south selling for £79 or Duckworths @ £188. Amazingly , I have an identical fault on the Porsche, they want almost £500 for their servo motor.. the joys.. |
