![]() | Home > Technical (L322) > TD6 Starting and loss of power |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3271 ![]() ![]() ![]() |
Fuel pump? John
jim4244 Member Since: 31 May 2012 Location: UK Posts: 855 ![]() ![]() ![]() |
I would go for the in line fuel pump situated under the near side rear passenger seat seat .
Boydonegood Member Since: 12 May 2014 Location: Essex Posts: 445 ![]() ![]() ![]() |
Oh awesome guys. Can it be intermittent? And effect the loss of power whilst driving?
One in the tank that lifts the fuel. One halfway along under the car and the final high pressure pump on the near side of the engine.
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
sure it is not throttle position sensor?
Deffo no leaks.
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 807 ![]() ![]() ![]() |
I had an issue with my car bogging down under load otherwise it ran fine. Turned out to be the in-tank pump. I changed just the pump but it comes as part of the sender assy. The whole unit is now pretty cheap if it turns out to be that.
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2718 ![]() ![]() ![]() |
I’ll vote for injectors , my old td6 was very intermittent until they finally said enough |
Ok so couldn’t replicate the issue this morning. Bloody thing started first time everytime!
What can sometimes happen is that the in tank pump fails or starts to give up the ghost so the in line pump then takes the full strain of sucking the fuel up from the tank and onto the HP pump. The in line pump will do quite a good job until it fails.
Cheers guys!!
Put inline pump on tonight and all seams fine at the moment. Starting ok and driving well.
Denise Pinky Member Since: 16 Sep 2021 Location: Co Durham Posts: 34 ![]() ![]() ![]() |
Did this fix your problem? |
