Home > Technical (L322) > TD6 Starting and loss of power |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3194 |
Fuel pump? John
3rd Mar 2021 7:12pm |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 843 |
I would go for the in line fuel pump situated under the near side rear passenger seat seat .
3rd Mar 2021 7:40pm |
Boydonegood Member Since: 12 May 2014 Location: Essex Posts: 445 |
Oh awesome guys. Can it be intermittent? And effect the loss of power whilst driving?
3rd Mar 2021 8:04pm |
One in the tank that lifts the fuel. One halfway along under the car and the final high pressure pump on the near side of the engine.
3rd Mar 2021 9:59pm |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
sure it is not throttle position sensor?
3rd Mar 2021 10:30pm |
Deffo no leaks.
3rd Mar 2021 10:49pm |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 775 |
I had an issue with my car bogging down under load otherwise it ran fine. Turned out to be the in-tank pump. I changed just the pump but it comes as part of the sender assy. The whole unit is now pretty cheap if it turns out to be that.
4th Mar 2021 5:12am |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2598 |
I’ll vote for injectors , my old td6 was very intermittent until they finally said enough |
4th Mar 2021 8:53am |
Ok so couldn’t replicate the issue this morning. Bloody thing started first time everytime!
4th Mar 2021 3:58pm |
4th Mar 2021 4:00pm |
What can sometimes happen is that the in tank pump fails or starts to give up the ghost so the in line pump then takes the full strain of sucking the fuel up from the tank and onto the HP pump. The in line pump will do quite a good job until it fails.
4th Mar 2021 4:03pm |
Cheers guys!!
4th Mar 2021 4:30pm |
Put inline pump on tonight and all seams fine at the moment. Starting ok and driving well.
5th Mar 2021 6:07pm |
Denise Pinky Member Since: 16 Sep 2021 Location: Co Durham Posts: 34 |
Did this fix your problem? |
16th Sep 2021 3:12pm |
