![]() | Home > Maintenance & Mods (L322) > Which rear diff?? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000 ![]() ![]() ![]() |
Unless you have the build sheet, the only sure way of knowing is to crawl underneath and see if you have an electrical connector going to it.
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 ![]() ![]() ![]() |
Capacities are very small according to this?
ilard Member Since: 21 Oct 2012 Location: London Posts: 715 ![]() ![]() |
Is there a 4x4 info screen that shows the diffs? On the latest vehicles, which are obverse different, there is a graphic that shows which differentials are active at the moment... in my case middle diff and rear diff. Else you can do a VIN lookup for spec. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso |
No cables or sockets on rear diff. 2010 3.6tdv8 180k km.
Nothing rear diff wise on the 4x4 info screen ?
https://www.fullfatrr.com/forum/topic47819...=rear+diff 2011 Range Rover Vogue SE 4.4 TDV8
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8778 ![]() ![]() ![]() |
Quite rare to find a locking diff on anything unless it was a standard fit. Almost never specified as an option as it was never really needed unless you get really stuck!
Nothing under the car ![]() sold 06 td6 160k Sold 03 td6 260k |
YES I always do the filler first. But I kinda scared a little like if I touch drains will start. 2010 3.6tdv8 180k km. sold 06 td6 160k Sold 03 td6 260k |
