![]() | Home > Maintenance & Mods (L322) > Which rear diff?? |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000
Unless you have the build sheet, the only sure way of knowing is to crawl underneath and see if you have an electrical connector going to it.
| umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433
Capacities are very small according to this?
| ilard Member Since: 21 Oct 2012 Location: London Posts: 717
Is there a 4x4 info screen that shows the diffs? On the latest vehicles, which are obverse different, there is a graphic that shows which differentials are active at the moment... in my case middle diff and rear diff. Else you can do a VIN lookup for spec. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso |
No cables or sockets on rear diff. 2010 3.6tdv8 180k km.
Nothing rear diff wise on the 4x4 info screen ?
https://www.fullfatrr.com/forum/topic47819...=rear+diff 2011 Range Rover Vogue SE 4.4 TDV8
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8786
Quite rare to find a locking diff on anything unless it was a standard fit. Almost never specified as an option as it was never really needed unless you get really stuck!
Nothing under the car sold 06 td6 160k Sold 03 td6 260k |
YES I always do the filler first. But I kinda scared a little like if I touch drains will start. 2010 3.6tdv8 180k km. sold 06 td6 160k Sold 03 td6 260k |
