Home > Off Topic > Trailer floor
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Trailer floor
I have been searching the net to find recommendations for trailer flooring, in particular what thickness board, cannot find anything so thought that I am bound to get some good advice here.
I restored the trailer back in 2012 but I never got around to replacing the floor and thought it would last a couple of years so I am amazed its lasted till now.
Its 6' x 4' has a central spine and cross members at 18" intervals, see picture.
I want to use a good quality phenolic coated board but at what thickness? I'm thinking 9mm but should I use 12mm?. It just gets used for general duties such as trips to the tip, the heaviest items its ever been used for is a medium sized mobility scooter and a 90cm range cooker.
Alternatively can I use Aluminium checker sheet? if so what thickness
 Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #586546 7th Mar 2021 3:03am
p38arover
Australia
Aluminium chequerplate min. 6mm
What about formply (used for forming up concrete)- like this: https://www.falconpp.co.uk/products/plywood/formwork-plywood/ Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #586547 7th Mar 2021 4:46am
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
I did a similar project many years ago and used 18mm marine ply. It hauled loads of building rubble whilst I renovated 2 houses we had. It was better the chequer plate in my view, easer to run a shovel along, sweep, slide sacks etc. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #586548 7th Mar 2021 7:18am
Furnitureman
United Kingdom 2012 Range Rover Westminster 4.4 V8 Cairns Blue
Most builders yards do a board especially for trailer bases it’s like a bitumen infused chipboard with a rubberised non slip surface very tough and for your trailer prob cost £40-£60 of the top of my head I’ll have a look for the receipt btw I’d go 18mm min 2012 Range Rover Westminster 4.4 TDV8
2006 Discovery 3 HSE 260k miles and still going strong with a new owner
Post #586550 7th Mar 2021 7:53am
Looking at the floor framing 12mm marine plywood would be more than adequate. Personally I would treat the underside of the board with waxoyl before fitting. Thumbs Up
Post #586551 7th Mar 2021 7:55am
At least 12mm I would say, and coated Phenloic board. Should last a while then, it’s the sort that most trailer manufacturers fit from the factory. Had our Indespension done a couple of years back before it wandered off..... There is nothing that can't be fixed with a hammer😜😜
Post #586569 7th Mar 2021 11:54am
LiftedDisco
Phenolic ply - avoid aluminium chequerplate like the proverbial plague as it’s filthy, hard to clean, noisy and slippery when wet.
The alternative is to use thermoplastic honeycomb panels - they are now using this for body’s for the various home delivery vans as it’s lightweight but strong as anything... http://www.coretexgroup.co.uk/6.html although others are available if you search for suppliers.
Post #586722 8th Mar 2021 8:08pm
bigbo
Thanks every one for your help and sorry for the lateness of my reply.
I have decided to go with 12mm Phenolic ply based on advice here and elsewhere .
David Range Rover 4.2 Supercharged 2006
MG TF 2003
Post #587612 15th Mar 2021 9:56pm
