Home > Off Topic > Trailer floor |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1516 |
Aluminium chequerplate min. 6mm
7th Mar 2021 4:46am |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1459 |
I did a similar project many years ago and used 18mm marine ply. It hauled loads of building rubble whilst I renovated 2 houses we had. It was better the chequer plate in my view, easer to run a shovel along, sweep, slide sacks etc. BMW i3 Electric Car
7th Mar 2021 7:18am |
Furnitureman Member Since: 26 Jan 2021 Location: Leicestershire Posts: 332 |
Most builders yards do a board especially for trailer bases it’s like a bitumen infused chipboard with a rubberised non slip surface very tough and for your trailer prob cost £40-£60 of the top of my head I’ll have a look for the receipt btw I’d go 18mm min 2012 Range Rover Westminster 4.4 TDV8
7th Mar 2021 7:53am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3954 |
Looking at the floor framing 12mm marine plywood would be more than adequate. Personally I would treat the underside of the board with waxoyl before fitting. |
7th Mar 2021 7:55am |
At least 12mm I would say, and coated Phenloic board. Should last a while then, it’s the sort that most trailer manufacturers fit from the factory. Had our Indespension done a couple of years back before it wandered off..... There is nothing that can't be fixed with a hammer😜😜
7th Mar 2021 11:54am |
LiftedDisco Member Since: 13 Nov 2019 Location: Towcester Posts: 31 |
Phenolic ply - avoid aluminium chequerplate like the proverbial plague as it’s filthy, hard to clean, noisy and slippery when wet.
8th Mar 2021 8:08pm |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 541 |
Thanks every one for your help and sorry for the lateness of my reply.
15th Mar 2021 9:56pm |
