![]() | Home > Maintenance & Mods (L322) > Oils at front side?? |
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 ![]() ![]() ![]() |
And just in front of transmission oil cartel:(
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8786 ![]() ![]() ![]() |
The transfer case doesn’t look too drastic. I would check around the output shaft seal, the solenoid and the high low position sensor, these are the only open points apart from the filler and drain. If they all look Ok then it could be the mastic seal which joins the 2 halves. But that’s more trouble than it’s worth as the case has to come out and unless it’s really peeing out then I wouldn’t worry.
Great info thanks
No not much, the case was damp but no drips. The o ring is on the High low position sensor which is a small black unit secured to the case with some wires into it. This is the sensor you can see the damage to the o ring.
I checked the engine for oil leak only things I could find are :
