Home > Maintenance & Mods (L322) > Oils at front side??
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
Hi
I did oil changes today and noticed these around cartel and hroug the engine.
This one is left side looking to the back of the car.
This hose right side of oil kartel looking back
And also around front differential plus transfer case.
Transfer case has minor leaks around marked points.
Any comments appreciated. 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #586588 7th Mar 2021 2:32pm
umitbat
And just in front of transmission oil cartel:(
sold 06 td6 160k
Sold 03 td6 260k
Post #586589 7th Mar 2021 2:37pm
The transfer case doesn’t look too drastic. I would check around the output shaft seal, the solenoid and the high low position sensor, these are the only open points apart from the filler and drain. If they all look Ok then it could be the mastic seal which joins the 2 halves. But that’s more trouble than it’s worth as the case has to come out and unless it’s really peeing out then I wouldn’t worry.
My trans case on my 07 3.6 was leaking for ages, LR re sealed it, still leaking, I eventually tracked it down to a fouled O ring on the high low sensor, cheap and easy fix in the end..... and doable on the drive in 5 mins.... so worth checking. It’s about the only thing high up on the case so if it looks like it’s running down then start there.
The rest look like they start high up so look from the top with the covers off. Could be rocker gaskets. There is nothing that can't be fixed with a hammer😜😜
Post #586595 7th Mar 2021 3:20pm
umitbat
Great info thanks
Does the leak cause too much fluid loss?
Is o ring easy to find? 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #586602 7th Mar 2021 3:59pm
No not much, the case was damp but no drips. The o ring is on the High low position sensor which is a small black unit secured to the case with some wires into it. This is the sensor you can see the damage to the o ring.
Whole new sensor wasn’t too much money, and doesn’t need coding. You could try replacing just the seal if that is where it is coming from. There is nothing that can't be fixed with a hammer😜😜
Post #586623 7th Mar 2021 6:23pm
umitbat
I checked the engine for oil leak only things I could find are :
Any ideas what the little hose there?Is it the one coming from air filter?
That is Left side of oil filter looking back.
and a moistured pipe; fuel line I guess:
The one at the bottom.only this one is like this. 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #586971 10th Mar 2021 7:12pm
