![]() | Home > Technical (L322) > Aux heater (used) needed L322 2011 |
Rodjules Member Since: 03 Mar 2016 Location: Bishops Stortford Posts: 68 ![]() ![]() ![]() |
Got this one from an earlier car but part number looks the same. Purchased second hand as fully working (3 month warrantee)
JNC Member Since: 23 Feb 2020 Location: UK Posts: 293 ![]() ![]() ![]() |
From what I understand of your post, your FBH is not working?
cattona Member Since: 27 Nov 2020 Location: Perthshire Posts: 38 ![]() ![]() ![]() |
First of all thanks for the offer of the extra unit. I have had aol email problems (still do, actually), so I never got alerts for any of these comments having come in. In the meantime, the mechanic has sourced a unit so I will leave this for someone else who can use it. Thanks for your generous offer.
Chris1573 Member Since: 30 Jan 2021 Location: Gloucestershire Posts: 162 ![]() ![]() ![]() |
The water pump is not inside the fbh its Attached to the end of it. You can remove and replace them. Steve at Webasto repairs sold me a tested used pump for £65... he also repaired my circuit board fault for £50.
Do you have a picture of the pump?
This is an example of the water pump.
The other common fault is the FBH fuel pump, this is located under the RR towards the fuel tank. Its quite simple to test if its working. L322 2007 TDV8 3.6 |
Same as...
