Home > Technical (L322) > Viscous fan bracket / pulley 4.4 tdv8 (2011 MY) - Brexit ?
klj
United Kingdom 2011 Range Rover Vogue 4.4 V8 Stornoway Grey
Morning all.
Decided to change all belts / water pump / pulleys on my 59k miles FFRR tdv8 4.4. Have got serious chirps squeeks etc.
Got hold of just about all of the parts except the the viscous fan bracket / bearing / pulley ( rarely changed it seems - no after market).
Tried my usual sources and all said that there are none in the UK, on back order and might be weeks. Spoke to LR who confirmed that a number of service parts have run out, including he one I need LR022810 - BRACKET - COUPLING SHAFT BEARING 4.4L. They are on "back order" he said and it looks like weeks rather that days. Did not seek to blame Brexit directly but something is going wrong with parts supply.
Anyone got one they need to sell?
Cheers
Post #586943 10th Mar 2021 3:00pm
Range Rover L322
Did you ever find one of these? - LR022810
I need one now and not available at the moment. Trying everywhere !!
Post #597714 16th Jun 2021 4:32pm
JCW
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
Could the bearings be replaced if identified & sourced separately?
Post #597720 16th Jun 2021 5:53pm
Range Rover L322
Good suggestion!!
I researched this - people have apparently tried to source the bearings but they are a one off barrel shaped affair which no bearing catalogues list unfortunately
Post #597727 16th Jun 2021 7:18pm
klj
Eventually got one from land rover. Waited months. Supplies now trickling through .... ----------------
2010 RR tdv8 3.6 ( gone but not forgotten ...)
2012 RR tdv8 4.4
2004 RR 4.4 V8 (M62) -gone but not forgotten (sob)
1998 P38 RR - least said the better
2009 BMW 7 Series 3.0d
Various motor cycles - BMW GS
1998 Jag XKr 4.0 V8
Post #597742 16th Jun 2021 10:56pm
Range Rover L322
Thanks for letting me know. Really appreciate it.
Post #597747 17th Jun 2021 12:28am
kevinp
Hi, when you got your old one off did you find any wear in the bearings? I'm currently getting all the parts together to do all the pulleys and wondered if it is worth replacing this one considering it's expensive and there are no after market ones which might point to the fact that it's more durable than the others. I am buying genuine parts only.
Cheers Kev.
Post #606850 20th Sep 2021 8:08am
klj
Hi. I thought it was a bit notchy buy once off the car it seemed totally OK. It was awkward to check in situ . Cheers . Ken ----------------
2012 RR tdv8 4.4
1998 Jag XKr 4.0 V8
Post #607258 24th Sep 2021 10:34pm
kevinp
Post #607263 25th Sep 2021 3:09am
DrRob
How long did it take in the end to get the part?
Might need one Big Cry Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #621965 31st Jan 2022 3:21pm
klj
Hi Rob. Four months! ----------------
2012 RR tdv8 4.4
1998 Jag XKr 4.0 V8
Post #623225 11th Feb 2022 12:06am
DrRob
Got one overnight from main dealer Thumbs Up
It was the main culprit for the horrible canary noise when cold or hot.
Replaced all pulleys, belts, idlers and its now A1 Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #623237 11th Feb 2022 9:07am
kevinp
Hi Rob, do you think it was the idler pulley or the fan attachment bearing that was making the noise on that part?
I'm still collecting all the pulleys to do mine and not sure whether to just replace the pulley.
Thanks Kev.
Post #623256 11th Feb 2022 10:05am
