![]() | Home > Technical (L322) > Viscous fan bracket / pulley 4.4 tdv8 (2011 MY) - Brexit ? |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 339 ![]() ![]() |
Did you ever find one of these? - LR022810
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 914 ![]() ![]() ![]() |
Could the bearings be replaced if identified & sourced separately? |
Good suggestion!!
klj Member Since: 24 Aug 2019 Location: Frozen North Posts: 66 ![]() ![]() ![]() |
Eventually got one from land rover. Waited months. Supplies now trickling through .... ----------------
Thanks for letting me know. Really appreciate it. |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1319 ![]() ![]() ![]() |
Hi, when you got your old one off did you find any wear in the bearings? I'm currently getting all the parts together to do all the pulleys and wondered if it is worth replacing this one considering it's expensive and there are no after market ones which might point to the fact that it's more durable than the others. I am buying genuine parts only. Cheers Kev. |
Hi. I thought it was a bit notchy buy once off the car it seemed totally OK. It was awkward to check in situ . Cheers . Ken ----------------
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
How long did it take in the end to get the part?
Hi Rob. Four months! ----------------
Got one overnight from main dealer |
Hi Rob, do you think it was the idler pulley or the fan attachment bearing that was making the noise on that part?
