Home > Technical (L322) > TDV8 4.4 engine rebuild, preventative mod info ?
Page 4 of 5 <12345>
Baltic Blue
Just an idea,..If it’s a very late L322 maybe it was seen as a prototype for the L405 ?.
Early L405 didn’t have the mod, but I don’t know at what stage they had it done at production.
Post #587128 11th Mar 2021 10:38pm
Autobiographyblack
Its not the first time ive used this crazy logic, in the past when ive fancied a car ive hunted down a broken one, that way i can do my best to future proof it and put right any wrongs properly as i go, i usually take them on myself but the range rover was a bit too much for me, luckily i have a friend that does this stuff regularly, hopefully it will make a nice example once done and if i keep a record of everything should make it easy to sell if i decide not to hang on to it.
Post #587129 11th Mar 2021 10:38pm
Autobiographyblack
Mike.
Its a sept 2010 build, so first of the 4.4’s
Post #587130 11th Mar 2021 10:39pm
Baltic Blue
It must have been modified at some time then.
The day I took mine in to the MD for the mod, I spoke to the mech who was given the job and he pointed to an L405 and said “ I have just finished that one”.
Post #587133 11th Mar 2021 10:49pm
GraemeS
Australia
An early vehicle which could easily have been one of the earliest to suffer the smoke problem, possibly after already having had the secondary turbo replaced but the problem persisted.
An 04/14 build L405 on this forum had a factory-fitted slightly different twin drain but L405s started with the same single drain as the L322.
Post #587138 11th Mar 2021 11:45pm
Autobiographyblack
Im struggling to find oil cooler seals, LR are saying on back order with no ETA.....
Now sorted, found some
Post #587169 12th Mar 2021 1:09pm
DrRob
My friend works at a garage at a garage in balsall common/coventry, thats where its being done, they do lots of JLR engine work, the place is called Lavender Hall Autos.
Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #587171 12th Mar 2021 1:21pm
Autobiographyblack
My friend is an old school mechanic and very much into doing things right, hes just called saying hes disgusted with how the oilcooler sits on the sandwich plate to the block, he said the cast of the sandwich plate is disgraceful and no wonder they all leak, he said, when you place the cooler on unbolted it rocks and in places has 30 thou gap, pulls down with bolts but he finds that very poor engineering.
Post #587179 12th Mar 2021 2:46pm
mjdronfield
And probably not helped either, by the constant heating up and cooling down.....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #587197 12th Mar 2021 5:15pm
Autobiographyblack
I said that but his response was if thats the case its bad design, either way a poor show
Post #587200 12th Mar 2021 5:20pm
mjdronfield
Oh yes, for sure. It’s such a common issue now. The specialist that did mine about 5 years ago, hadn’t done many oil coolers. Within a year they had done over a dozen....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #587209 12th Mar 2021 6:16pm
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
this is why i replaced the whole cooler!! have to say when i put the new one on it did not rock. but equally i did not have the engine on a stand either. perhaps that is why they have the rubber compression gaskets i did find them odd given the bif temp swings they go through.
I wanted to change my thermostat while at no other reason that the car was in bits, but the housing is plastic and prone to braking when trying to remove and i could not find anyone with one in stock + they are expensive. so i left it. 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #587605 15th Mar 2021 9:02pm
GraemeS
Australia
Mine certainly didn't rock when I fitted new gaskets. I would not have proceeded with such a condition.
Post #587606 15th Mar 2021 9:05pm
Autobiographyblack
He did say it seems to pull dow straight once tightened down
Post #587608 15th Mar 2021 9:08pm
Autobiographyblack
After some thought and considering GraemeS comment ive now decided to order a new cooler to be safe.
Post #587684 16th Mar 2021 6:22pm
Page 4 of 5 <12345>
