When I did mine last year I already had the battery disconnected and the E brake was already OFF. (we were replacing the entire rear suspension bits) so I thought why not chuck in new disks, pads, shoes and as it happens all brake lines.
Then I did pretty much what you did for a standard brake shoe procedure, ie tighten until lock up and back off until wheel turns with just a hint of noise.
(just a thought, closely check that you have positioned the EPB springs correctly, it is reasonably possible to have them backasswards).
It was then a couple of weeks until the RR was back on the road before I could follow the EPB procedure. My EPB will bring the RR to a stop all by itself, or it will hold station no problem.
I'd do your manual adjustments again, but also reread the procedure before you go on the attack.
Best of luck. L322 3.6 TDV8 Vogue. 07MY
ML 320 7 Seat full leather etc. (The Black Pearl)
