![]() | Home > Technical (L322) > Gear change |
| Chris1573 Member Since: 30 Jan 2021 Location: Gloucestershire Posts: 162
So I checked with the garage who did the oil flush and they use Rockoil ATF D6 oil. Is this suitable for the ZF box ? L322 2007 TDV8 3.6 |
| Wk52RR Member Since: 29 Dec 2020 Location: Devon Posts: 54
This is not the correct oil. I used genuine zf oil in mine. Not massively more expensive but it’s guaranteed to be right. |
Thanks Wk52RR. L322 2007 TDV8 3.6 |
| diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 491
The Rock oil is the correct spec and should not cause the slow gear change, I use rock oil in mine and have no problem. |
| garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1494
Did they also change the valve body seal?
“ Did they also change the valve body seal? ”
There is only one valve body seal. It's inside the gearbox above the mechatromics pack. It looks like this:
OK Did the filter and oil change and it does feel a bit better, took over 5 litres of the lifeguard 6 oil.
Worst case, you're looking at a mechatronics pack repair or replacement. Neither are expensive to do. |
| All times are GMT |
