Home > Technical (L322) > Sounds expensive
Wogger
England 2010 Range Rover Vogue TDV8 Orkney Grey
Sounds expensive
This morning my 2010 L322 3.6 diesel developed a rattling noise which I can only describe as coming from behind the fan
Any ideas chaps?
Would it be a timing issue?
And do I need to sell a kidney ?
Motor has done abou 130,000 miles.
Be gentle with your replies Big Cry
Post #589450 29th Mar 2021 11:32am
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
It’s a diesel they make rattling noises 🤷‍♂️😬
Other than that, how long is a piece of string. It could be as simple as a bolt that is loose on the cowel.
Post #589451 29th Mar 2021 11:36am
Discotigger
It could be one of the pulley belt tensioners starting to fail. Mine made a ticking noise when they started to go, getting them looked at and replaced as we speak.
Post #589466 29th Mar 2021 4:43pm
Wogger
It was the water pump pulley, and belt, the bolts in the pulley had failed.
40 quid repair, kidneys intact.
Thanks for the advice chaps Thumbs Up
Post #589482 29th Mar 2021 6:36pm
Bl4ckD0g
I must admit I’m impressed with myself to diagnose loose bolts remotely.
Go Bl4ckD0G Go Bl4ckD0G Bow down Laughing
Post #589495 29th Mar 2021 9:14pm
