Home > Maintenance & Mods (L322) > Too Much Oil - 4.4 TDV8
Mike Edwards
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
According to the dash my recently acquired '11 TDV8 has too much oil in it.
Is it just a case of finding the sump plug bolt and letting some out and, if so, how much should I be aiming to lose?
The indicator on the dash shows it very nearly to the top of the 'bar'.
Post #589640 31st Mar 2021 11:39am
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
Does the display say it's overfilled or are you just seeing the level is close to the top of the gauge? 2011 TDV8 Vogue SE
Post #589641 31st Mar 2021 11:47am
dennij
This thread may help too
https://www.fullfatrr.com/forum/topic40450...level+cold 2011 TDV8 Vogue SE
Post #589642 31st Mar 2021 11:48am
Mike Edwards
It says it is quite a way beyond the maximum indicator.
Post #589644 31st Mar 2021 11:54am
Mike Edwards
That looks interesting. Thanks.
Post #589645 31st Mar 2021 11:55am
DrRob
8.5L at oil change NOT what the manual says Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #589649 31st Mar 2021 12:00pm
DrRob
Suck it out via the vacuum pipe on top of engine. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #589650 31st Mar 2021 12:01pm
IGP
United Kingdom 2013 Range Rover Vogue SE SDV8 Siberian Silver
DO NOT try and remove the sump bolt and then put it back in. You will end up with about 9 litres of oil all over the place. Ask me how I know.
Ivan 2013 Vogue SE SDV8
2013 Freelander 2 SD4 HSE Luxury
Post #589655 31st Mar 2021 12:17pm
bishbosh10
Also be aware that the gauge is very sensitive to gradients. the car must be on an absolutely flat and level surface or the gauge to read correctly. Even a small incline can have a significant impact on what the gauge says. Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #589662 31st Mar 2021 1:07pm
