![]() | Home > Technical (L405) > 5L Supercharged, Oil In Coolant |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
At first I thought you meant supercharger oil in coolant, now that would have been 'interesting'. But I guess its not identified that it is supercharger oil, but just oil into your coolant on a 5.0 supercharged engine...
Hammer Member Since: 14 Oct 2012 Location: Perth Posts: 124 ![]() ![]() ![]() |
Thanks Bl4ckDog
Thanks 2015 AB 5.0 Supercharged
I don't know on how to test it without getting to it. A visual inspection may reveal what's up. It could be just gasket, or whatever. Considering the costs of the parts, I would just change the lot as missing something and doing it again would cost more in labour. But any garage, main dealer or indy used to these engines should be able to do that fairly quickly. It is just that that lovely supercharger is in the way.
Did yours also leak into the radiator coolant? 2015 AB 5.0 Supercharged
No my leak was coolant out of the system and depositing it without trace; well with the V. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8713 ![]() ![]() ![]() |
You don't usually get oil in the water with a head gasket, the water system is under pressure so if you have a leak you will usually get water in the oil and an emulsification around the cap...
Hi Pete, Yes it is new to me.
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1393 ![]() ![]() |
Float the oil off the top, get your level correct and watch it for a few days for any changes to levels or increases in oil, you might be lucky that some dope has topped up the wrong reservoir in the past.
Thanks dingg1,
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
That is very clean looking oil.
If im lucky, they just dense ๐
Dont underestimate how dense people can be especially when their mind is on other things.
Funny you say that, a mate of mine phoned once saying his honda was blowing alot of smoke after toping it up with oil.
