Home > Maintenance & Mods (L405) > Tow assist
Dshort86
United Kingdom 2013 Range Rover Autobiography SDV8 Santorini Black
Tow assist
Looking for to get some insight on Tow Assist. I have just retrofitted a tow bar to a MY 2013 L405 AB, the trailer electrics work fine, but I was wondering how I initiate tow assist on the cameras?
Post #590791 10th Apr 2021 4:13pm
It should ask you to set it up when you plug in a trailer sir... Thumbs Up
Post #590833 11th Apr 2021 12:50am
Mine didn’t either....
Is there some CCF editing that needs doing when a tow bar is fitted. I’m thinking my installer didn’t do it so I too have working electrics and dash warning but no reversing camera assistance..... There is nothing that can't be fixed with a hammer😜😜
Post #590846 11th Apr 2021 9:51am
Dshort86
It’s odd, when electrics are plugged in it knows that a trailer is connected as the green symbol appears on the dash. In addition to the Tow assist not being an option the park sensors are also active when reversing (very annoying unless manually turned off). It seems like something is missing.
Post #590879 11th Apr 2021 1:06pm
Same. There is nothing that can't be fixed with a hammer😜😜
Post #590880 11th Apr 2021 1:22pm
What lights are on your trailer? The RR only knows your trailer is fitted when the brake light circuit senses the trailer brake lights... If your trailer has LED lights? That can be a problem...
Post #590947 11th Apr 2021 11:42pm
Dshort86
It’s a good old iForwilliams using standard bulks.
Post #591000 12th Apr 2021 3:58pm
pierre_l
Switzerland 2014 Range Rover Autobiography SDV8 Santorini Black
anyone found a way to start the towing menu in the computer by any chance?
Post #644915 6th Oct 2022 2:21pm
James W
Saudi Arabia 2017 Range Rover Autobiography SDV8 Siberian Silver
Although your green indicator repeater lamp will work if you add a towbar and electrics, you will need someone with a suitable system (Dealer SDD system or Autologic I assume? Not sure if IID can do it) to 'enable' full towing functionality including disabling the reversing sensors when towing. I am in the same boat, I need to ask my indy to do this when it's next services. FFRR SDV8 Autobiography
Post #644922 6th Oct 2022 3:23pm
zenman63
England 2018 Range Rover SVAutobiography 5.0 SC V8 Firenze Red
The IID tool does enable the tow assist and all it needs.
Mine is odd as the trailer symbol doesn’t work with the indicators, trying everything.
Post #645019 7th Oct 2022 3:36pm
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
My new to me L405 has it but all I can see it helps to reverse you which I can do myself, am I missing something Thumbs Up
Post #645030 7th Oct 2022 6:03pm
zenman63
It stops the suspension dropping, turns off the parking sensors, zooms in on the tow hitch and when set up aids reverse, you need the white sticker mounted and set up the trailer dimensions etc.
Post #645031 7th Oct 2022 6:20pm
ajac8
Don't confuse hitch assist with tow assist. I don't think the white triangle hitch assist is available on the 2013 405.
I have the factory deployable tow bar and tried everywhere to get the hitch assist enabled. Turns out the functionality is not fitted to my vehicle. An indy in London who specialises in 'switching things on' and other enhancements for RR confirmed this via my VIN.
Bit disappointing but not really a biggy.
Come to think of it, when I last reversed with the caravan hooked up the reverse sensors were still active.
I'd be interested to see if tow assist must be enabled. You would have thought with a factory tow bar it would be! 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #645117 8th Oct 2022 6:38pm
TJH1985
I have tow assist, and IMO it’s just a gimmick I think I’ve used it maybe twice, and have taken the triangles off now.
Ours is an after market tow bar so presumably was activated when the car was programmed. The only thing I use is the hitch assist to reverse up to the tow ball, and then the ability to raise / lower the back of the car with the key fob to help hitch up.
As soon as you plug in the electrics it detects the trailer and starts the tracking once you confirm it’s connected on the display. I also notice a change in engine tone when you plug in, as well as parking sensors etc being disabled.
I had to fit a module to the van, as it has LED lights that caused the car to not recognise anything was connected, so if you have parking sensors coming on either it’s not coded or you might have the same issue with LED lights. Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #645121 8th Oct 2022 7:20pm
zenman63
If you parking sensors are active then it still needs coding.
It should then open up hitch assist
Post #645122 8th Oct 2022 7:20pm
