Home > Maintenance & Mods (L405) > Tow assist |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16146 |
It should ask you to set it up when you plug in a trailer sir... |
10th Apr 2021 11:50pm |
Mine didn’t either....
11th Apr 2021 8:51am |
Dshort86 Member Since: 28 Mar 2021 Location: Manchester Posts: 15 |
It’s odd, when electrics are plugged in it knows that a trailer is connected as the green symbol appears on the dash. In addition to the Tow assist not being an option the park sensors are also active when reversing (very annoying unless manually turned off). It seems like something is missing. |
11th Apr 2021 12:06pm |
Same. There is nothing that can't be fixed with a hammer😜😜
11th Apr 2021 12:22pm |
What lights are on your trailer? The RR only knows your trailer is fitted when the brake light circuit senses the trailer brake lights... If your trailer has LED lights? That can be a problem... |
11th Apr 2021 10:42pm |
It’s a good old iForwilliams using standard bulks. |
12th Apr 2021 2:58pm |
pierre_l Member Since: 06 Oct 2022 Location: Geneva Posts: 4 |
anyone found a way to start the towing menu in the computer by any chance? |
6th Oct 2022 1:21pm |
James W Member Since: 29 Nov 2009 Location: Wirral Posts: 283 |
Although your green indicator repeater lamp will work if you add a towbar and electrics, you will need someone with a suitable system (Dealer SDD system or Autologic I assume? Not sure if IID can do it) to 'enable' full towing functionality including disabling the reversing sensors when towing. I am in the same boat, I need to ask my indy to do this when it's next services. FFRR SDV8 Autobiography |
6th Oct 2022 2:23pm |
zenman63 Member Since: 14 Nov 2021 Location: Warwickshire Posts: 125 |
The IID tool does enable the tow assist and all it needs.
7th Oct 2022 2:36pm |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2539 |
My new to me L405 has it but all I can see it helps to reverse you which I can do myself, am I missing something |
7th Oct 2022 5:03pm |
It stops the suspension dropping, turns off the parking sensors, zooms in on the tow hitch and when set up aids reverse, you need the white sticker mounted and set up the trailer dimensions etc. |
7th Oct 2022 5:20pm |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1619 |
Don't confuse hitch assist with tow assist. I don't think the white triangle hitch assist is available on the 2013 405.
8th Oct 2022 5:38pm |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 663 |
I have tow assist, and IMO it’s just a gimmick I think I’ve used it maybe twice, and have taken the triangles off now.
8th Oct 2022 6:20pm |
If you parking sensors are active then it still needs coding.
