![]() | Home > Technical (L322) > 2002 ff 4.4 zf5hp lost reverse gear |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 539 ![]() ![]() |
It's pretty hard to say without being stripped for inspection.
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1014 ![]() ![]() |
I would suggest that you temporarily disconnect the 16-pin connector at the back of the transmission. This forces the transmission into failsafe mode and then the hydraulic feed to the C & F clutches is at full system pressure and there is no electronic or electrical intervention from the controller or solenoids. If the vehicle still won’t reverse when warm, then you have a mechanical problem (most likely a seal) and the transmission will have to be stripped.
Bronjen Member Since: 13 May 2018 Location: DE2 Posts: 44 ![]() ![]() ![]() |
Hi Phil
Hi Phil
So, it would appear that both the C & F clutches are functioning correctly and that the hydraulic pressure to one (or both) is being incorrectly modulated, somehow, in normal operation.
fanders Member Since: 10 Jul 2013 Location: Hants, UK Posts: 318 ![]() ![]() ![]() |
Hee hee, love pictures of a gearbox in bits like that Phil, thanks for posting and good to see you on the forum again.
Hi Phil
I’ll keep my fingers crossed for you that it’s a valve body issue.
Hi Phil just dropped transmission pan and found this spacer or shim on the left rear magnet in the pan
Wow, I’ve never seen that happen before |
Hi Phil yes it looks like the one in your picture, so box out that's the weekend used up lol |
