![]() | Home > Technical (L322) > Indi can't talk to control modules after compressor refurb |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
Please ignore this if I am, quote 'stating the bleedin obvious'
RSW Member Since: 13 Oct 2015 Location: Devon Posts: 44 ![]() ![]() |
Thanks for taking the time to reply.
I am not the best at electrical fault finding, but first I would check to see if you have current to the compressor, as you said, fuses already checked.
As an addition, as yours is a 2002, not sure, my screen has the facility for the hidden menu, check this, also the 2006 has a screen that can show off road info to see if all height seensors are at the same setting, sorry, do not know if the 2002 has this facility. Just thinking back to are all height sensors ok.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8718 ![]() ![]() ![]() |
Usually if the diagnostic tool won't talk to the car it is a fault with the tool, or the tool is not suitable, not all tools will talk to fatties, most will read engine faults but little else...
RichTD6 Member Since: 02 Mar 2011 Location: Lincolnshire Posts: 85 ![]() ![]() ![]() |
Is it worth checking the compressor relay as I have seen that when changing the compressor for a new one, the supplying companies recommend a new relay at the same time?
Thanks RichTD6 I will check the relays
Most scanners will read and clear emission faults, and some other basic problems, but may not be getting enough access to clear your current problem.
