Home > Maintenance & Mods (L322) > 2011 4.4 tdv8 over heating
Gizmo
2011 Range Rover Vogue SE TDV8 Santorini Black
Hi all
I have a 2011 4.4 tdv8
Today I have started to get over heating. She stays at normal temp when idling but when driving she goes up and occasionally hits red and I have to stop. I have checked everything through with no signs of leaks or drop in level.
I ran a diagnostic and no codes.
Any body got any ideas
Patrick
Post #591626 18th Apr 2021 5:56pm
DrRob
Sounds like a thermostat.... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #591629 18th Apr 2021 6:09pm
mjdronfield
I’m thinking thermostat too...... radiator not blocked?
Enough oil and coolant? Assume so, as you say you’ve checked everything.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #591634 18th Apr 2021 6:16pm
Sounds thermostatty Thumbs Up probably stuck shut.nothing much to the engine cooling system bar a pump, header tank, some hoses and the stat. So long as you haven’t lost coolant, and don’t have a big leak then start with the stat as it’s the cheapest fix option. There is nothing that can't be fixed with a hammer😜😜
Post #591639 18th Apr 2021 6:29pm
Gizmo
Thanks all for that. Will get thermostat sorted and let you know how I get on.
One think to note is that I had to have a new emission gas sensor ( was stopping dpf regen )changed and a forced dpf clean.
To that end I had full service as is wise after a dpf burn and all was in order that’s why I’m confident on the oil level etc.
Post #591643 18th Apr 2021 6:43pm
If it’s got so little oil that it’s overheating, you have bigger problems so that’s unlikely! There is nothing that can't be fixed with a hammer😜😜
Post #591647 18th Apr 2021 6:57pm
DrRob
Which sensor was changed? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #592503 27th Apr 2021 7:50am
Gizmo
Morning Rob
The sensor changed was the oxygen sensor on bank 2. The awkward one on the near side exhaust manifold
Post #592504 27th Apr 2021 8:03am
DrRob
Thanks for update. We’re you getting frequent amber DPF ? What codes came up?
Who did the work for you ?
Thanks in advance Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #593428 6th May 2021 10:25pm
