![]() | Home > Maintenance & Mods (L322) > Electric Bike Rack and no towbar |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
LR didnt sell a deployable towbar for the L322 sir... Only a fixed or detachable socket type... |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1417 ![]() ![]() ![]() |
The LR rack that bolts into the tow bar armature is quite sturdy, but you'd need to check weight limits. Because you have to lift the bicycle to locate the frame on the arms of the carrier and then secure the frame and the wheels to stop them spinning, one tends to need lots of straps and it is not as convenient as some other kinds. But some of the lower level ones with a clamp (like the LR Accessory one for the 405) have weight limits that might be a problem, the two bicycle one for the 405 for example would be too low a limit for your two bicycles. Only Range Rovers since 1988 |
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 ![]() ![]() |
Craig - it is a rack for an electric bike, not an electric rack for a bike! |
RiverBlanche Member Since: 20 Apr 2021 Location: Retford'ish Posts: 97 ![]() ![]() |
Hi,
