Home > In Car Electronics (L405) > Internet connection whilst in car
dentaldave
United Kingdom 2018 Range Rover Autobiography SDV8 Farallon Black
I can connect my iPhone to the RR so it shows a tick and although the vehicle is connected to my external WiFi at home I cannot access a web search on my iPhone.
I have a current micro sim inserted which has plenty of available data on it.
Can any connectivity expert explain where I am going wrong?
Post #592709 29th Apr 2021 7:09pm
Kot
In connectivity, scroll down and select Hotspot, this allows your phone to use your Data sim etc 2018 SE SDV8 4.4 Byron Blue
Post #592763 30th Apr 2021 10:27am
dentaldave
Yes that is already done .all is as it should be but still no access
Post #592767 30th Apr 2021 11:08am
Chalky
Has it worked before? If so take the sim out, clean the contact area and re-insert. If that doesn't work try another sim card and if still no joy it could be the sim reader has stopped working and needs replacing. All LR cars from 1984
2021.5 Vogue SE D300 Carpathian Grey
2018 Vogue SE British Racing Green GONE
Post #592768 30th Apr 2021 12:18pm
Chalky
Also is Data roaming on, on your phone? All LR cars from 1984
Post #592769 30th Apr 2021 12:19pm
dentaldave
Yes data roaming is on on iPhone. I have had car 4 months and never had it working ( so far)
I will try cleaning the contacts
Post #592815 30th Apr 2021 6:39pm
dentaldave
The contacts on the sim are clean. When I bought the car there was no sim inserted but Marshall Peterborough supplied one.
Post #592816 30th Apr 2021 6:47pm
Chalky
What Simcard is it? Is it data only, have you tried the sim in your phone?
The best one is from 3. It's called "Internet with Legs" and you have a choice of card size.
I think I'd call the dealer and tell him it isn't working and let them deal with it, if it's all still in Warranty. All LR cars from 1984
Post #592817 30th Apr 2021 7:00pm
Chalky
Post #592818 30th Apr 2021 7:02pm
dentaldave
It is a Ubigi micro sim as provided by our local JLR dealer in Peterborough.
The car is still under its original warranty and I am it’s sec owner.
I have managed to get the line of first prior to the signal bars. The Ubigi online instructions says connect can take up to two minutes but I have waited much longer than that. We do live in the country so I will keep an eye to see if a set of bars finally
Arrive . If not a visit to Marshalls may well be the next step!
Post #592824 30th Apr 2021 9:10pm
Chalky
Is your SIM card internet data only? The dealer should have provided the correct one but you never know. I’ve never heard of the one you’ve got. I presume it fits the slot ok and is not loose or has to be forced? All LR cars from 1984
Post #592826 30th Apr 2021 9:19pm
dentaldave
I also have the same in an I-PACE so may try that. It fits the slot well and you can see track marks on the metal surface
Post #592827 30th Apr 2021 9:31pm
dentaldave
I presume it is data only. At present the capacity is replenished once a month by JLR but the current one shows zero usage
Post #592828 30th Apr 2021 9:33pm
dentaldave
My I-PACE picks up 4G straight away and is 500mb. It’s card does not work in the Range Rover though whose card is 100mb only. I don’t know why the I-PACE card wouldn’t work in the RR unless there is a fault in the card reader. Do you think the card should be interchangeable?
Post #592830 30th Apr 2021 10:06pm
Chalky
Not sure if it would be interchangeable. I’d give the dealer a call and see what they say as it’s on warranty All LR cars from 1984
Post #592831 30th Apr 2021 10:09pm
