![]() | Home > In Car Electronics (L405) > Internet connection whilst in car |
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1377 ![]() ![]() |
In connectivity, scroll down and select Hotspot, this allows your phone to use your Data sim etc 2018 SE SDV8 4.4 Byron Blue |
dentaldave Member Since: 24 Dec 2020 Location: lincolnshire Posts: 41 ![]() ![]() ![]() |
Yes that is already done .all is as it should be but still no access |
Chalky Member Since: 10 Feb 2018 Location: Marshfield, Bath Posts: 931 ![]() ![]() |
Has it worked before? If so take the sim out, clean the contact area and re-insert. If that doesn't work try another sim card and if still no joy it could be the sim reader has stopped working and needs replacing. All LR cars from 1984
Also is Data roaming on, on your phone? All LR cars from 1984
Yes data roaming is on on iPhone. I have had car 4 months and never had it working ( so far)
The contacts on the sim are clean. When I bought the car there was no sim inserted but Marshall Peterborough supplied one. |
What Simcard is it? Is it data only, have you tried the sim in your phone?
It is a Ubigi micro sim as provided by our local JLR dealer in Peterborough.
Is your SIM card internet data only? The dealer should have provided the correct one but you never know. I’ve never heard of the one you’ve got. I presume it fits the slot ok and is not loose or has to be forced? All LR cars from 1984
I also have the same in an I-PACE so may try that. It fits the slot well and you can see track marks on the metal surface |
I presume it is data only. At present the capacity is replenished once a month by JLR but the current one shows zero usage |
My I-PACE picks up 4G straight away and is 500mb. It’s card does not work in the Range Rover though whose card is 100mb only. I don’t know why the I-PACE card wouldn’t work in the RR unless there is a fault in the card reader. Do you think the card should be interchangeable? |
Not sure if it would be interchangeable. I’d give the dealer a call and see what they say as it’s on warranty All LR cars from 1984
