![]() | Home > Maintenance & Mods (L322) > ENGINE SYSTEM FAULT? |
| dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1416
It just likes to worry you |
| kgeddes Member Since: 11 Jan 2015 Location: UK Posts: 289
Thanks Dingg1 |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
Defo get the codes read with a decent diagnostic.... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Read codes with iCarsoft reader:
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35872
this might be related,
Thanks Stan, I’ll have a read through |
Is this likely to be caused by a split in a top intercooler hose?
thats one of the first things i would check , underneath the hoses as well. ... - .- -.
Thanks again Stan, a job for today |
Both top hoses removed, cleaned and checked….both in perfect condition.
because its an intermittent fault it could be it sticking now and again... ... - .- -.
Thanks Stan, I’ll get the actuators checked/lubricated and go from there…..
| Zeb Member Since: 04 Oct 2016 Location: Lincolnshire Posts: 134
I think what is described here is the occassional, random and very momentary popping up of the 'Engine System Fault' message which occurs as the car is turning over but actually before it has actually started. No other accompanying warning lights. Mine does this perhaps every 2-3 weeks. It started after the starter motor was replaced. As it happens when the engine isn't actually running I haven't followed it up yet. The car continues to run perfectly. I am curious as to what it might be however! |
Thanks zeb. Yes the situation is exactly as you describe. I have had battery drain issues recently resulting in a replacement battery and a new alternator both which were not required as the drain was finally traced to fuse 49! The ENGINE SYSTEM FAULT message started at this time- I put it down to a low battery but now that the issue has been resolved the message is still randomly appearing!
