Home > Maintenance & Mods (L322) > ENGINE SYSTEM FAULT?
kgeddes
United Kingdom 2013 Range Rover Autobiography SDV8 Causeway Grey
Every 5 to 10 days I get the ENGINE STSTEM FAULT message for a second just as the engine starts on the first start of the day. It does not come on at any other time.
The FF runs and starts perfectly.
Any ideas why I am getting this occasional message?
Thanks in advance...
Post #593447 7th May 2021 8:17am
dingg1
It just likes to worry you Laughing
Sorry, couldn't help it Cool
How about you get any codes read and take things from there Thumbs Up
Post #593453 7th May 2021 8:24am
kgeddes
Thanks Dingg1 Laughing
Yes, it really enjoys worrying me!!!
I’ll get the codes read, thanks Thumbs Up
Post #593455 7th May 2021 9:05am
DrRob
Defo get the codes read with a decent diagnostic.... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #593469 7th May 2021 10:53am
kgeddes
Read codes with iCarsoft reader:
No faults found relating to engine.
Noted the following readings with engine running at idle:
Boost pressure actuator Bank 1 - 0.76%
Commanded boost actuator control Bank 1 - 76.47%
Commanded boost actuator control Bank 2 - 76.08%
Swirl valve actuator 95%
Does this all look ok?
Thanks....
Post #593486 7th May 2021 2:01pm
this might be related,
https://www.fullfatrr.com/forum/topic41533...stem+fault
or this,
https://www.fullfatrr.com/forum/topic51059...p;start=15 ... - .- -.
Post #593487 7th May 2021 2:08pm
kgeddes
Thanks Stan, I’ll have a read through Thumbs Up
I don’t understand why no fault is showing up on the reader given that the car showed ENGINE SYSTEM FAULT this morning?
Maybe I’m not using the iCarsoft properly....
Post #593488 7th May 2021 2:30pm
kgeddes
Is this likely to be caused by a split in a top intercooler hose?
I know one of them has been replaced.
Post #593582 8th May 2021 11:04am
thats one of the first things i would check , underneath the hoses as well. ... - .- -.
Post #593585 8th May 2021 11:17am
kgeddes
Thanks again Stan, a job for today Thumbs Up
Post #593590 8th May 2021 11:35am
kgeddes
Both top hoses removed, cleaned and checked….both in perfect condition.
No DTC on reader.
Last ENGINE SYSTEM FAULT message was on Thursday morning on first start, nothing since. Vehicle running perfectly.
Could it be actuator/s needing lubricated?
Post #593672 9th May 2021 10:48am
because its an intermittent fault it could be it sticking now and again... ... - .- -.
Post #593674 9th May 2021 11:07am
kgeddes
Thanks Stan, I’ll get the actuators checked/lubricated and go from there…..
Still can’t understand why no DTC has been logged and reported on the reader Question
Post #593732 9th May 2021 9:08pm
Zeb
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
I think what is described here is the occassional, random and very momentary popping up of the 'Engine System Fault' message which occurs as the car is turning over but actually before it has actually started. No other accompanying warning lights. Mine does this perhaps every 2-3 weeks. It started after the starter motor was replaced. As it happens when the engine isn't actually running I haven't followed it up yet. The car continues to run perfectly. I am curious as to what it might be however!
Post #593743 10th May 2021 6:59am
kgeddes
Thanks zeb. Yes the situation is exactly as you describe. I have had battery drain issues recently resulting in a replacement battery and a new alternator both which were not required as the drain was finally traced to fuse 49! The ENGINE SYSTEM FAULT message started at this time- I put it down to a low battery but now that the issue has been resolved the message is still randomly appearing!
How long has yours been doing this for?
Post #593747 10th May 2021 8:17am
