Home > Technical (L405) > Sensible Air Flow Sensor Readings
Mike Edwards
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
Plugged my IID Tool in to a friend’s L405 today.
Was expecting the air flow readings to be the same for each bank.
Should they be the same and, if so, what would a normal reading at idle be?
Post #593157 4th May 2021 6:54pm
Mike Edwards
Am I to assume that absolutely nobody has ever hooked up an IID unit to their diesel L405 and looked at the MAF numbers?
Post #593780 10th May 2021 3:01pm
i looked in the WM [link in the wiki] and found this..apparently only one MAF sensor gives output which would account for your readings ???,
Post #593781 10th May 2021 3:18pm
Mike Edwards
I read that to be temperature from one but air flow reading from both.
If not, why would you bother fitting a second unit?
Post #593848 11th May 2021 7:54am
dont know but theres a lot more to read in the WM...my pic is just a small extract from it.. ... - .- -.
Post #593851 11th May 2021 8:49am
Mike Edwards
Finally worked out why I was getting confusing numbers from the different MAF sensors.
It is a sequential turbo as we know, the confusion stemmed from why at idle it was showing such very different readings.
It appears that once it is warmed up there is no air through the second turbo until the revs get to around 3k rpm.
What I was seeing, and what was confusing, is why there is a small amount of air passing through at idle.
It turns out that when cold the second turbo does do very small amount of work, I can only assume to get things warmed up a little quicker.
NO idea why but will keep investigating if anyone is interested.
Post #595573 27th May 2021 10:21pm
jumpin mouse
United Kingdom 2015 Range Rover Autobiography SDV8 Aruba
I'm interested Mike, I like to keep learning.
Thanks.
Post #595592 28th May 2021 7:47am
