Home > In Car Electronics (L322) > 2006 L322 Sat nav unit - options to replace missing unit |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2180 |
Have you got rear screens? Current stable:
11th May 2021 10:54pm |
chrisv Member Since: 01 Apr 2021 Location: East Mids Posts: 10 |
I have rear screens and a boot DVD changer (subject to repair). No headphones for the rear though (something else to source).
12th May 2021 8:42am |
I was going to suggest ripping it all out but with rear screens the job gets harder without making a dogs dinner of of it.
12th May 2021 9:46am |
Thanks Dan --
12th May 2021 9:47am |
lschwarcz Member Since: 18 May 2019 Location: Hillsboro, OR, USA Posts: 266 |
Do you know what's specifically wrong with the sat nav? In my case the nav DVD drive in the back was broken. I bought one off of eBay for $90 (USD) that works perfectly! If the display works fine then you may just need a replacement drive. Just make sure you get the right one for your car!
12th May 2021 4:13pm |
The unit was removed completely and, I assume, was binned along the way leaving a gap in the frame and the wiring dangling forlornly. --
12th May 2021 4:41pm |
Hmmmm. If the wiring is still there you may be able to plug in a replacement unit and get functionality back!
12th May 2021 4:46pm |
I've looked on ebay and I can get a replacement unit. However, given that the most up to date disc I can get is likely to be a few years old, I'd like to take the opportunity to look at an upgrade option.
12th May 2021 6:14pm |
I don't know anything about Naviplus but I just installed the NavTool in my '09.
12th May 2021 6:49pm |
Thanks Larry - useful feedback. They imply that you can use Navtool without the OEM sat nav but it seems not.
13th May 2021 9:40am |
You may be better off gutting it and and putting a nice 10.25 androids screen in and normal headrests.
16th May 2021 6:37pm |
Fitting an aftermarket Android unit as suggested by Danwilderspin may be a perfect solution! But just be aware that you will lose some functionality. You certainly won't get the 4X4 screen and I'm not sure how you'd do other tasks like setting the clock. There may be a work around but I'm not aware of them.
16th May 2021 7:03pm |
The clock you need to rig a hidden button to cut the power twice a year you press at 12
16th May 2021 7:28pm |
I did think about ripping it all out TBH.
18th May 2021 9:10am |
