Home > Technical (L322) > Filling up upside down?!
TDV8 Paul
Hey all, I’ve an odd one here, had this issue since I bought the car last year.
Basically when I fill up, unless I insert and hold the petrol dispenser upside down I cannot get a continuous flow without the annoying click every few seconds, it’s annoying and I get the strangest looks. I’ve tried it at every filling station I’ve been too (and that’s a few as we know!) and it’s not specific to one company, it happens at every one.
Anyone have this or can shed any light on this?
It’s so weird!!!! 2009 (2010 MY) 5.0 Supercharged Autobiography
2007 TDV8 Vogue SE
2005 BMW E63 645ci
2024 Porsche Macan
Post #594077 13th May 2021 7:43am
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
Think it’s a quirk of the filler neck, used to do this every fill on the old l322, you are not alone lol.
Post #594079 13th May 2021 7:59am
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Check inside your filler that the yellow miss fuel has not been tripped? It will trip if it has had a fill from a can spout inserted?
Post #594080 13th May 2021 8:02am
Not quite upside down but l have turned the nozzle upwards over 90 degrees ever since l have had the car, over 10 years.
I just find it works better even if it does look a bit odd. Second nature now. Thumbs Up
Post #594081 13th May 2021 8:23am
Merchy
.... then check to see if the plastic reset tool is still with the car Whistle
Post #594082 13th May 2021 8:25am
If you pull it out slightly you don't have to turn it so far, there is a sweet spot between insertion length and angle.... (ooh err Mrs..!)
I do find my 2012 is much better than my 2002 was so they did something to improve it....! Pete
Post #594084 13th May 2021 8:43am
TDV8 Paul
Well, at least I’m not the only one then! I’ve tried the 90 degrees and no result!
The car does indeed have the yellow reset doobie buried in the boot somewhere I saw, so just to rule it out I’ll give it a try, that’s a good shout, thanks guys 2009 (2010 MY) 5.0 Supercharged Autobiography
2007 TDV8 Vogue SE
2005 BMW E63 645ci
2024 Porsche Macan
Post #594086 13th May 2021 8:44am
TDV8 Paul
I’ll try and put the tip in and go from there.... 2009 (2010 MY) 5.0 Supercharged Autobiography
2007 TDV8 Vogue SE
2005 BMW E63 645ci
2024 Porsche Macan
Post #594087 13th May 2021 8:45am
Mr Tee
watch you don't break your tool, they are brittle.... a long pozi screwdriver works alot better, if you shine a torch down, you'll see if the mechanism has tripped, it's quite obvious when you have light. Thumbs Up
Post #594102 13th May 2021 10:04am
Snowy90 L322
United Kingdom 2019 Range Rover Vogue SDV6 Baltic Blue
Pull out method always a winner in this house!
Post #594108 13th May 2021 10:35am
TDV8 Paul
It’s worked well in this house so I’ll see if the luck continues with the car! 😂 2009 (2010 MY) 5.0 Supercharged Autobiography
2007 TDV8 Vogue SE
2005 BMW E63 645ci
2024 Porsche Macan
Post #594196 14th May 2021 6:57am
Sam
Yep, had the same with mine, and mine hadn't had the misfuel device tripped. As has said before, I think it's just a quirk of the filler neck not venting as well as it should. Bizarrely, once I'd managed to get the tank half full I could shove it all the way in and it was fine..... Phnar phnar.
Post #594211 14th May 2021 9:41am
TDV8 Paul
Interesting, I’ll try that too, maybe just need warming up before going in properly 2009 (2010 MY) 5.0 Supercharged Autobiography
2007 TDV8 Vogue SE
2005 BMW E63 645ci
2024 Porsche Macan
Post #594247 14th May 2021 3:16pm
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Never had a problem with any of my petrol fueled cars but the Diseasel fueled S max I had was a PITA to fill up. No amount of twisting the nozzle helped! I guess it was due to the tendency for the diesel to "foam" when exiting the pump nozzle. Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #594255 14th May 2021 5:28pm
