Home > Technical (L322) > L322 Suspension Calibration
harleyman
Spain
Hi all,
I`ve been checking the forum but I still have some doubts about suspension and OBD tools and hope you can help me
My car (It`s been with me three weeks and nearly 100 miles) all suspension works ok (I had to clear the famous suspension dryer brass cone exhaust je je) and since then everything seems ok (I don´t get any errors)
the thing is that distance between the wheel center cap and the wheel arch it not the same in the four corners (some the difference is not very high but the rear right has is 3cm lower that the others)
I use the car only for traveling and I don´t use it offroad
The distance has to be the same in the four corners? I mean that the correct suspension calibration should be the four corners with the same distance between the wheel center cap and the wheel arch?
then my other question is regarding the OBD Tools. I`ve seen that the one to go for is the IDD Gap, but as I don`t think I will be using it for more things that resenting the service warning and calibrate the suspension.
Is it usual that the suspension needs to be calibrated?
Is there any other tool cheaper than the IID that could allow me to calibrate de suspension?
I hace to say that suspension holds the sir properly and the difference between corners is the same even if I lower or rise the suspension. and I can leave the car for days parked and all corners stay still (none of the go down)
Thank you 2012 Range Rover 4.4 tdv8 Autobiography
Post #594088 13th May 2021 8:51am
get it on a very flat surface and use these measurements,
Post #594090 13th May 2021 8:55am
harleyman
Spain
Thank you Stan
great info for me
now lets see if forum members let me know if the car goes out of adjustment very often or not and what would be the cheapest know tool that will allow me to adjust it 2012 Range Rover 4.4 tdv8 Autobiography
Post #594100 13th May 2021 9:50am
Snowy90 L322
United Kingdom 2004 Range Rover HSE Td6 Giverny Green
Bite the bullit and get the IID the non blue tooth version is cheaper and often come up second hand and switch the licence over. It will do what you want and save you loads during your ownership.
There maybe others but i only use the IID.
Post #594110 13th May 2021 10:39am
harleyman
Spain
Thank you,
I think that the non bluetooth it's no longer available and I think it does not support the 2010-2012 FF 2012 Range Rover 4.4 tdv8 Autobiography
Post #594118 13th May 2021 11:33am
Snowy90 L322
Apologies, i didn't know that, i picked up a BT one off a member here it was about £250.00 plus £25 to change licence.
Post #594122 13th May 2021 11:50am
harleyman
Spain
Really good price for a BT one
what do you think about this one?
https://www.rswsolutions.com/index.php/dis...ostic-tool
Post #594134 13th May 2021 1:17pm
bishbosh10
From the 2010-12 Workshop Manual:
https://www.fullfatrr.com/gallery/albums/u...ights..pdf Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #594136 13th May 2021 1:35pm
stevepen
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Stornoway Grey
First time I've seen this info. Had to rush out and measure mine and it's spot on to the mm. Something not to worry about now. 2011 Vogue SE TDV8
Post #594138 13th May 2021 2:13pm
paulparry82
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Barolo Black
GAP IID Tool
I used the gap IID BT tool to recalibrate mine after changing the front air bag. It guides you through each corner with the measurements required from centre point of the wheel to the underside of the wheel arch, you can manually adjust up or down on the app screen (I just used a tape measure to get it to the required height).
Post #616894 19th Dec 2021 12:54pm
JayGee
Even on a perfectly flat surface each corner can be +/-10mm before teh system will adjust unless it's in a special tight tolerance mode' as this prevents excessive compressor operation. Front are also 10mm higher than the rear ( allegedly to offset nose dive / weight transfer under braking). Well worth getting the GAP IID tool as the guided calibration procedure is very quick and easy. 2012 TDV8 Vogue (L322)
Post #616907 19th Dec 2021 2:18pm
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
looked every where for those measurements a couple of days ago, thanks RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #616917 19th Dec 2021 3:25pm
JayGee
Tips- measuring accurately from the wheel centre is tricky so measure the diameter of your centre cap and deduct 1/2 that from your calibration height and measure from the top of the centre cap. 2012 TDV8 Vogue (L322)
Post #616918 19th Dec 2021 3:39pm
Billie
England 2006 Range Rover Vogue 4.2 SC V8 Buckingham Blue
suspension
Thank you Mr Stan, just what we were looking for Thumbs Up
Post #616960 20th Dec 2021 7:47am
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
Another tip to measure very accurately. Use some old Center caps. Dremel a little slot in them in the center and then stick a card in them. Makes it very easy to use a laser measure to get an accurate height to the Center.
Post #616981 20th Dec 2021 11:15am
