![]() | Home > Maintenance & Mods (L322) > Roof bars |
007smith Member Since: 27 Mar 2021 Location: Lincolnshire Posts: 4 ![]() ![]() ![]() |
Looking for roof bars for my L322 59 Reg. Don't want to install roof rails and don't really want to use the feet back that clamps under the door frame.
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
There are, they are called sports bars. I had a set for my full fat, they worked very well |
Jimnic007 Member Since: 13 Aug 2019 Location: Cheshire Posts: 74 ![]() ![]() ![]() |
I am looking for the same but can't find any.
gravitylover Member Since: 08 Nov 2020 Location: Southeast NY Posts: 36 ![]() ![]() ![]() |
They used to but discontinued that particular fit kit a while back |
Anvil Member Since: 18 Jan 2019 Location: Dorset Posts: 140 ![]() ![]() |
Think I may be going down this route......
Unistrut channel on spacer blocks bolted into the grub screw holes. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8751 ![]() ![]() ![]() |
Don’t even know if the sports bars are available to order from LR. I would doubt it but might be worth giving duckworthparts a shout. There is nothing that can't be fixed with a hammer😜😜
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1469 ![]() ![]() |
This thread suggests they may not be ideal..... https://www.fullfatrr.com/forum/topic59333.html 2021 D350 Fifty Edition - Carpathian Grey 2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black 2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black |
Agree they are not ideal but only for occasional use. A mate of mine used one for years for surf boards and rated it. I’d likely only be using it for an inflatable paddle board and short journeys so should suit my needs. FFRR 4.2SC/KTM 990SMT Current and cherished.
I need bars for a roof box, so don't think they will work, but thanks for the heads up |
Is the solution not built in with an inflatable paddle board. There is nothing that can't be fixed with a hammer😜😜
Should still keep the majority of roof/item contact to a minimum, and easier to put a non-slip grip mat under the inflatable rack. Hopefully that would minimise any paint damage, and strapping down becomes easier with the built in d-rings too. FFRR 4.2SC/KTM 990SMT Current and cherished.
I've been trying to figure out a safe solution that can handle a load up to 150 pounds. Is this stuff structurally strong enough if it was attached at all three mounting points on each side? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8624 ![]() ![]() ![]() |
Official weight limit is 100lbs but IMHO it will take significantly more, well in excess of what you need, COG will be raised though so bare that in mind... Pete
