Home > Maintenance & Mods (L322) > Roof bars
007smith
United Kingdom 2009 Range Rover Vogue SE TDV8 Stornoway Grey
Roof bars
Looking for roof bars for my L322 59 Reg. Don't want to install roof rails and don't really want to use the feet back that clamps under the door frame.
Are there any with foot packs that screw in to the rail holes?
Post #595364 26th May 2021 10:27am
GraemeC
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
There are, they are called sports bars. I had a set for my full fat, they worked very well Thumbs Up
They looks like these on eBay, but obviously you will need a Full Fat version (these are RR Sport specific)
https://www.ebay.co.uk/itm/114807638299?ep...SwJ8FgntVE 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #595382 26th May 2021 1:34pm
They are however like hens teeth.
You flip up the little covers on the Rails and remove the grub screws. They then screw down to the roof with an security torx screw.
Work well, I did have a set for my 322 but sold them to Haylands.... if you find a pair, then be careful not to break the little covers on the roof trim, they can’t be bought separately, and require removing the entire trim To replace...! There is nothing that can't be fixed with a hammer😜😜
Post #595540 27th May 2021 5:41pm
Jimnic007
United Kingdom 2012 Range Rover Vogue TDV8 Nara Bronze
I am looking for the same but can't find any.
Does anyone know if Thule (or similar) do a set that would fit with no rails?
Thanks
James
Post #595844 30th May 2021 12:05pm
gravitylover
United States 2006 Range Rover Supercharged 4.2 SC V8 Alveston Red
They used to but discontinued that particular fit kit a while back Sad
Post #596715 7th Jun 2021 2:36pm
Anvil
Think I may be going down this route......
https://www.amazon.co.uk/gp/product/B002YH..._597961681 FFRR 4.2SC/KTM 990SMT Current and cherished.
Honda Accord 2.4 Vtec touring. (Yeah, I know, think: Kids)
Mitsubishi Pajero Evolution Nut-wagon. and a Buell XB12R
TVR Griffith 5.0 (backed up with Vauxhall Carlton road barge for the weekly shop.)
Honda Integra Type R DC2 Possibly the best drivers car. Ever.
Mitshibishi FTO GPX MIVEC.
Honda CRX Vtec Mk2 -NO, Not the del sol!!!
Volkswagen Scirocco GT
Mini 1275GT
MG Midget (Heavily modified)
I'm going to stop now.....
Post #596722 7th Jun 2021 2:57pm
Unistrut channel on spacer blocks bolted into the grub screw holes.
Post #596726 7th Jun 2021 3:01pm
Don’t even know if the sports bars are available to order from LR. I would doubt it but might be worth giving duckworthparts a shout. There is nothing that can't be fixed with a hammer😜😜
Post #596751 7th Jun 2021 6:06pm
Rob99
This thread suggests they may not be ideal.....
https://www.fullfatrr.com/forum/topic59333.html 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #596760 7th Jun 2021 7:07pm
Anvil
Agree they are not ideal but only for occasional use. A mate of mine used one for years for surf boards and rated it. I’d likely only be using it for an inflatable paddle board and short journeys so should suit my needs. FFRR 4.2SC/KTM 990SMT Current and cherished.
Mini 1275GT
Post #596764 7th Jun 2021 7:32pm
Jimnic007
I need bars for a roof box, so don't think they will work, but thanks for the heads up
Post #596780 7th Jun 2021 9:37pm
Is the solution not built in with an inflatable paddle board. There is nothing that can't be fixed with a hammer😜😜
Post #596785 7th Jun 2021 11:07pm
Anvil
Should still keep the majority of roof/item contact to a minimum, and easier to put a non-slip grip mat under the inflatable rack. Hopefully that would minimise any paint damage, and strapping down becomes easier with the built in d-rings too. FFRR 4.2SC/KTM 990SMT Current and cherished.
Mini 1275GT
Post #596806 8th Jun 2021 11:11am
gravitylover
I've been trying to figure out a safe solution that can handle a load up to 150 pounds. Is this stuff structurally strong enough if it was attached at all three mounting points on each side?
Post #596885 8th Jun 2021 11:40pm
Official weight limit is 100lbs but IMHO it will take significantly more, well in excess of what you need, COG will be raised though so bare that in mind... Pete
-Click here for Thread-
Post #596889 8th Jun 2021 11:53pm
