Home > Maintenance & Mods (L322) > Seized bolts… what do we do before we start cutting?
Page 2 of 3 <123>
Ffrr-lover
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Merchy wrote:
When working on the suspension, one of these breaker bars is very handy.
Get the type where the head swivels past 90 degrees, bloody handy for awkwardly positioned bolts.
https://www.eurocarparts.com/p/masterpro-b...-538773840
Also, for seriously tight / seized bolts, ( The below ) flogging spanners are very handy. Whereas you could damage other spanners by hammering, these are designed to take serious abuse from lump hammers. With these, the design has a good face for striking with said hammer, unlike standard spanners with rounded edges.
https://www.ebay.co.uk/itm/203473341048?ha...SwGOFgpUBr
Oh, and as an aside, a good pair of gloves to avoid any 'hammer rash' Thumbs Up Very Happy
Added to the wish list Thumbs Up Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #595738 29th May 2021 11:56am
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
If you use an impact gun I would recommend getting some impact sockets as you can split normal ones if you exert too sharp a shock to them . 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #595740 29th May 2021 12:48pm
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
nicedayforit wrote:
Make sure you use 6 sided sockets on the nuts and bolt heads, 12 sided sockets will cause you grief. Thumbs Up
+ 1 on 6 sided sockets, even better make sure they are all impact gun grade ! Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #595748 29th May 2021 2:51pm
Range Rover L322
XCP is getting good reviews. I will be buying that when I run out of WD40
Post #595773 29th May 2021 7:23pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Forget WD40 for anything other than cleaning or dispersing water. Plus Gas is a great penetrating fluid, do yourself a huge favour, buy it in bulk (5 litres) and get a pump spray bottle. Soak the offending items twice daily for a week before commencing work. Ive never had it fail. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #595774 29th May 2021 8:15pm
Merchy
As for the question earlier on - 'Are there any issues with these anti seize liquids? Such as they cause problems with rubber?'
I would not get any of this on the air bags for instance, but when changing suspension components, most of the time, the rubber parts ( Bushes etc ) are being changed anyway, just clean up the area thoroughly before fitting new components, and avoid any over spray ie brake components etc. Should be ok then.
Have fun with the big hammers. Some say, engineering is knowing what size hammer to pick up, and then how hard to hit something Rolling with laughter There is an element of truth there Whistle
Post #595775 29th May 2021 8:43pm
RJH
England 2011 Range Rover Vogue TDV8 Santorini Black
I’ve recently replaced all the front suspension on my 2011.
Didn’t have any seized bolts but I’d sprayed several times over a week with WD40s penetrating fluid not the normal wd40. I don’t think it penetrated the threads that well though. I was after Duck oil but I couldn’t get it in lockdown.
When you’re done, Torque everything back up dry though.
Rob. 2011 (MY12) 4.4 TDV8 Vogue
2016 Golf GTI PP
Gone
Audi A4
VW Passat
VW Corrado G60
VW Golf GTI
BMW E30
Mini
Vauxhall Chvette
Post #595776 29th May 2021 9:06pm
paulwlincs
I use Normfest super crack ultra ice rust removal , never fails amazing stuff . Having spent my working life in engineering I thought I knew a bit but this stuff is magic . 2011 tdv8 4.4 vogue Santorini black
Post #595778 29th May 2021 10:19pm
Ffrr-lover
Cheers Rob, that’s a fair comment! Obvious when you know… just not when you don’t! Laughing
Does the spray leave a residue that needs to be cleaned off before putting things back together? Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #595789 30th May 2021 7:15am
Ffrr-lover
Had a quick google for this… lots of pages selling the stuff but the few pages where people talk about the stuff and it’s all good! Like you say, it’s magic!!! Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #595790 30th May 2021 7:22am
Ffrr-lover
And thank you again Merchy! Very helpful advice! Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #595791 30th May 2021 7:23am
RJH
No real residue left, will usually evaporate off. Should replace nuts & bolts with new ones. Often ball joints come with new nuts if not, order some as cheap enough.
Depends on what you are replacing as to how easy it'll be, if doing the ball joints I sprayed where these went into the hub also. used a cold chisel & worked on the tab on either side working it out evenly. Took a bit of effort but wasn't as bad as I expected. Also make sure you support the weight with axle stands.
2016 Golf GTI PP
Gone
Audi A4
VW Passat
VW Corrado G60
VW Golf GTI
BMW E30
Mini
Vauxhall Chvette
Post #595794 30th May 2021 8:01am
AJGalaxy2012
Rob.
Thats sound engineering advice with one caveat, the friction encountered with used / rusty nuts, bolts and washers is totally different to new nuts, bolts and washers. I allow some leeway and make sure anti-seize compound is on the threads to save grief in the future. You have to take this into account though if youre going down this route. BMW i3 Electric Car
Post #595798 30th May 2021 8:35am
Soaking for a few days is a great idea, that said, they are nothing like as bad a D3/4 or RRS for seizing bolts sir Thumbs Up
Post #595916 31st May 2021 1:46am
Ffrr-lover
AJGalaxy2012 wrote:
Rob.
Ive read many times you should use new nuts and bolts every time, and as they are so cheap it seems silly not to!
I also had a google about the reduction of torque when using anti seize… and the suggestion I found was to reduce the torque setting by 25-30% https://blog.fcpeuro.com/6-tips-for-effective-use-of-anti-seize
Does that seem right to people? Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #595981 31st May 2021 5:35pm
Page 2 of 3 <123>
