Home > Technical (L322) > My New RR 3.6 TDV8 Has Just Broken Down Turbo/ or EGRs
theanswers
Ireland
Hey Folks.
So, I've been lurking around this forum for a while over the past few years and have had many RRs with many problems!
Anyways, I recently purchased a fairly clean RR 3.6 TDV8 Vogue SE with 127,000 miles.
Having had a previous RR inject it's EGRs and knacker the engine I decided this time to blank my EGRs.
Did this today and all was well... untill!
I was accelerating with full throttle then pop and sudden power loss.
I pulled in and noticed a lumpy idle, and little white smoke (not alot).
I plugged in my scanner and it came up with EGR faults, but nothing else.
So what are we thinking folks EGRs or Turbos?
Post #596338 3rd Jun 2021 7:57pm
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
What year is it - maybe update your profile? - and did you map out the EGRs? 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #596341 3rd Jun 2021 8:20pm
theanswers
Ireland
It's a 2008 RR 3.6 TDV8.
Afraid I didn't map out he EGRs. Was going to do it this evening.
It does seem like something failed though.
I felt a sudden change in pressure, like a pop.
No EML until 20 seconds after said pop.
I scanned the faults and then noted three EGR fails, which even after clearing didn't improve the lump idle.
Wouldn't rev much either.
Post #596343 3rd Jun 2021 8:35pm
MikeO
Have you checked the usual culprits, intercooler hoses? 2016 Skoda Octavia VRS Estate
Post #596359 3rd Jun 2021 10:26pm
theanswers
Ireland
I had a look and didn't see any cracks. All were attached.
I'm really starting to think turbo.
Hopefully not more damage done.
Twice, if such is the case that I lost an engine in a tdv8 because of egrs and turbos...
Hopefully not.
Post #596363 3rd Jun 2021 10:42pm
mjdronfield
Hopefully it’s not that, and something daft.
I skipped the 3.6. It’s not really cricket if you get clobbered twice.
If you recently purchased it, have you no redress with the seller?
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #596365 3rd Jun 2021 11:10pm
theanswers
Ireland
Hopefully not..
Will know more in the next few days. Currently awaiting the machinaic to review it.
Private sale and he's in Liverpool and I'm in Ireland so no luck. Anyways he's a decent fellow, this is just one of those things.
Just hoping we can get her running again. I plan to use it for the honeymoon in August in Scotland.
Post #596431 4th Jun 2021 10:21pm
lostinespace
United Kingdom 2009 Range Rover Vogue SE TDV8 Zambezi Silver
Did you clear the codes? The EGR should in theory be isolated from the engine now, even if it fails the performance should be good and you get codes. Mine throws the odd code about one EGR bank issue, but it usually goes away on restarting. I have blanked the EGRs.
How about the turbo actuators, maybe give them an exercise and oil. Passenger side tricky but doable. 2009 TDV8 3.6
Post #596674 6th Jun 2021 11:11pm
theanswers
Ireland
I cleared the fault codes, but currently the only ones showing is
P140A - Exhaust Gas Recirculation C - Circuit Low
P1623 Immobiliser Code
P010C Mass or volume air flow b - Circuit Low
Now I did some digging around this evening to have a look at her.
Here's what I've noticed thus far.
Oil Level is fine no drops.
Coolant is slightly low, but not sure if it was like this before hand.
The two intercooler pipes have a small amount of oil in them, but nothing out of the ordinary.
The mechanic is going to look at it tomorrow to see what he can discover. I will then report back. I'm really hoping it's something simple.
It was like something just went pop, and then the lumpyish idle started!! Sad
These hoses had a very small amount of oil in them, nothing out of the ordinary.
This hose on the left hand side was slightly crushed has if it was sucked inwards?
This is all I have so far folks!
Post #596712 7th Jun 2021 2:18pm
mjdronfield
The hoses can collapse as they weaken with age. That’s why many folk swap them out for silicone ones.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #596728 7th Jun 2021 3:14pm
lostinespace
Does sound like a collapsing hose. 2009 TDV8 3.6
Post #596732 7th Jun 2021 3:53pm
theanswers
Ireland
What would the symptoms of a callasped hose be like?
Would it cause the problems I'm describing?
Hopefully it's a simple fix!!
Post #596779 7th Jun 2021 9:02pm
Sam
If you haven't already replaced those 2x top hoses it's worth doing anyway as sooner or later they WILL split. But also if they're starting to collapse you're going to get and airflow restriction which may well explain the fault codes you're getting. You should be able to get the pair for around £120, and they only take around 20 mins to fit.
Post #596798 8th Jun 2021 9:02am
theanswers
Ireland
Thanks Sam for the advice. I changed the hoses on my last 3.6 so will likely do the same with this one. Currently still none the wiset as to the problem. Once I determine the current fault I will decide what to do.
I'm still hopeful nothing was sucked into the engine with turbo failure if that is what happened.
Post #597009 9th Jun 2021 10:14pm
theanswers
Ireland
Hey Folks.
So It's bad news!
The LH Turbo has failed. The mechanic is stripping it tomorrow to see what damage if any has befalen the engine.
1. Oil out the LH intercooler hose.
2. Lumpy Idle, he doesn't think any damage has been caused to the engine.
This is where I'm at.
Hopefully engine is OK, because this car was bought for my honeymoon for touring Scotland later in the summer!
Post #597640 15th Jun 2021 7:50pm
