![]() | Home > Technical (L322) > 4.2 SC Misfire help please |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3321 ![]() ![]() ![]() |
I’d start with the easiest thing first, swap the coils from cylinders 2 and 4 with another 2 cylinders and see if the misfire follows the coils.
Dode4444 Member Since: 18 Jan 2021 Location: Buckie Posts: 43 ![]() ![]() ![]() |
Car has done almost 150k miles…..
Yea, it’s not too bad.
Just watching a video on it just now like you say looks pretty easy so thank you…..
Cylinder 1 is the front offside, 2 is the front nearside.
Thank you 2005 (55) Range Rover 4.2 Supercharged Vogue SE Java Black |
Mikebob Member Since: 10 Jun 2019 Location: Pretoria Posts: 10 ![]() ![]() ![]() |
Check your fuel pressure as well |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2246 ![]() ![]() ![]() |
Check the little boost pipe between sc and fuel pressure sensor Current stable:
Still trying to find out the reason for this misfire and have came across this plug and can’t see where it would go.
Is it the plug from the fuel pressure sensor? Whip the engine cover off four but it’s on the right if you’d rant on front of it with a boost pipe going to it Current stable:
Hi,
Mine is in bits at the moment so I’ll have a look tomorrow and see if I can find your plug. It doesn’t look familiar though I’m afraid.
Thanks very much,
Just to be sure, that’s a grey 2 pin plug? What colour are the wires going into it? If you follow the wires back, where do they leave the main loom? 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
