Home > Technical (L322) > 4.2 SC Misfire help please
Dode4444
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Java Black
Evening all.
As the title says…..
I developed a misfire under heavy acceleration tonight and car threw a ‘reduced engine performance’ message along with the EML for around 5 seconds then disappears.
Car is running perfectly normal otherwise and feels like it’s running on all cylinders until it gets to 4-4.5k rpm.
Then it splutters and gives a rattling noise in the engine until throttle is backed off.
My generic code reader shows P0302 & P0304 misfire detected on cylinders 2&4.
I was actually warming the car up at the time to diagnose an intermittent EML for what I suspect to be a bad 02 sensor as I am getting weird voltage figures from them. Not sure if this could be connected however the 02 sensor problem is ongoing and has never caused a misfire before.
Attached is a snapshot of the o2 sensor voltages in case it is relevant.
Thanks.
 2005 (55) Range Rover 4.2 Supercharged Vogue SE Java Black
Post #598329 22nd Jun 2021 12:08am
dhallworth
I’d start with the easiest thing first, swap the coils from cylinders 2 and 4 with another 2 cylinders and see if the misfire follows the coils.
If it does you’ve got your fault, if it doesn’t it could be plugs.
How many miles has your car done as it could be worth doing all of the plugs anyway if they’ve not yet been done.
Post #598330 22nd Jun 2021 12:12am
Dode4444
Car has done almost 150k miles…..
Is swapping the coils an easy enough task? 2005 (55) Range Rover 4.2 Supercharged Vogue SE Java Black
Post #598331 22nd Jun 2021 12:13am
dhallworth
Yea, it’s not too bad.
There’s a plastic cover over the top of them that you can pull off and then there’s one bolt holding the coil in. Remove the plug and the bolt and give them a good tug and they’ll come off.
If it hasn’t had the plugs done at 150k it’s probably worth doing them too.
Post #598332 22nd Jun 2021 12:17am
Dode4444
Just watching a video on it just now like you say looks pretty easy so thank you…..
Can someone tell me what side of the engine is bank 1 & 2 if I am standing at the front of the car facing the engine please? 2005 (55) Range Rover 4.2 Supercharged Vogue SE Java Black
Post #598333 22nd Jun 2021 12:24am
dhallworth
Cylinder 1 is the front offside, 2 is the front nearside.
Post #598334 22nd Jun 2021 12:45am
Dode4444
Thank you 2005 (55) Range Rover 4.2 Supercharged Vogue SE Java Black
Post #598335 22nd Jun 2021 12:47am
Mikebob
South Africa 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Check your fuel pressure as well
Post #598342 22nd Jun 2021 6:04am
Danwilderspin
Check the little boost pipe between sc and fuel pressure sensor Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #598420 22nd Jun 2021 9:23pm
Dode4444
Still trying to find out the reason for this misfire and have came across this plug and can’t see where it would go.
Anybody have any ideas?
Post #602804 4th Aug 2021 3:11pm
Danwilderspin
Is it the plug from the fuel pressure sensor? Whip the engine cover off four but it’s on the right if you’d rant on front of it with a boost pipe going to it Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #602838 4th Aug 2021 8:30pm
Dode4444
Hi,
Had the cover off there but couldn’t see anything that didn’t have a plug in, everything seemed to have a plug in it as it should.
Could It be a spare or is it definitely meant to go somewhere in folks opinion?
Thanks. 2005 (55) Range Rover 4.2 Supercharged Vogue SE Java Black
Post #602890 5th Aug 2021 1:09pm
dhallworth
Mine is in bits at the moment so I’ll have a look tomorrow and see if I can find your plug. It doesn’t look familiar though I’m afraid.
Post #602948 5th Aug 2021 10:10pm
Dode4444
Thanks very much,
Had the airbox and intercooler plastic intake off today again but can’t see any connectors etc missing a plug. All plugs and connectors I could see were full. I’m starting to think it’s always been loose and I’ve just never noticed. 🤷🏻‍♂️ 2005 (55) Range Rover 4.2 Supercharged Vogue SE Java Black
Post #602950 5th Aug 2021 10:15pm
dhallworth
Just to be sure, that’s a grey 2 pin plug? What colour are the wires going into it? If you follow the wires back, where do they leave the main loom? 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #602951 5th Aug 2021 10:30pm
