Home > Maintenance & Mods (L405) > strange whine
aguiness
United Kingdom 2017 Range Rover Vogue SE TDV6 Aruba
strange whine
i have a whine when accelerating and you can hear it when you are driving but if you go into neutral it disappears and if you dont press the accelerator it also disappears its not overly loud but its there anyone else experienced this
Post #598316 21st Jun 2021 10:24pm
Ukandrewf
Could be a split turbo hose? Sounds like when you plug a blade of grass between ur hands and blow?
You only hear on acceleration because that’s when turbos engage.
My car is in with the same issue.
They also said exhaust manifold warped… --
On my third Full Fat RR
Post #598317 21st Jun 2021 10:26pm
aguiness
Its going in on the 16th for a service and also the oil sensor in the sump issue ill get them to check thanks
Post #598318 21st Jun 2021 10:29pm
pld118
Is it anything like this?
https://www.fullfatrr.com/forum/topic56221...=rear+diff
Post #598319 21st Jun 2021 10:36pm
The diffs can condensate and then the main bearing can whine under load... Have you ever checked the oil condition?
Post #598326 21st Jun 2021 11:33pm
aguiness
I havn't checked the oil yet. you dont hear the noise when free wheeling only when the accelerator is pressed and driving.
Post #598351 22nd Jun 2021 9:58am
Exactly…
Post #598358 22nd Jun 2021 11:55am
Sounds like diff or driveline whine to me too. Had the same problem in our old hilux, diff whined under load, then squealed, then made horrid noises. New diff required, so a quick change of diff oils and see how it goes. There is nothing that can't be fixed with a hammer😜😜
Post #598386 22nd Jun 2021 4:53pm
aguiness
Great thanks
Post #598468 23rd Jun 2021 3:08pm
RRBlue
England 2005 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Any update? My 5.0 SC whines between 70 and 75 mph when applying power. Not at any other time. 2014 5.0 L405 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2005 4.2 L322 Supercharged Vogue SE & 2011 3.0SDV6 HSE Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
2010 Freelander 2 TD4 HSE
2009 Freelander 2 TD4.e 2009
1992 Mercedes 300D
1986 Renault 2.1 Turbo D
1976 Morris Marina 1.8
Post #642876 13th Sep 2022 5:38pm
aguiness
Hi
the whine is still there changed the diff oil and the transfer box oil will be doing the gearbox oil later
Post #643475 21st Sep 2022 10:15am
