![]() | Home > Technical (L322) > P040D-00 (2F) EGR temperature sensor replacement |
| MTG2020 Member Since: 24 Feb 2020 Location: Caerphilly Posts: 35
Thanks. I have been following your excellent write up to do the job, so I've seen this pic. I will try again tomorrow, whether permitting, once I have trimmed more off the top of the sensor. |
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561
Have you moved both heat shields?
No only the rear one. The nut appears to be accessible, when I checked with my Endoscope. See pic.
I found the both had to move. A little bit of that second shield was fouling the socket
thinking about your RP... so no other error codes?
So, here's my story of woe. |
Hi Mark, well the car looks great. Your attention to air leaks seems sensible.
Hi GGDR. The sensor is not going well.
This is the smoke tester. It's designed exactly for what I used it for. I opened up both the opposite air box and the the turbo inter-cooler hose. In both cases, the smoke came gushing through, so I'm pretty confident there are no leaks. |
and are you on a yellow or red DPF warning ?
It's went red last week, but I've been leaving the IID plugged in and get the "Mrs" to clear the dtc's, which is about every one or 2 minutes. It also pushed the red warning back to Amber. |
Ok so it seems simple to me - that is your RP.
BTW Think I'll ask Stan to put page 4 posts on a separate thread
