Home > Technical (L322) > 6HP26 Torque Converter Differences |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7909 |
My thought would be that they sized the S/C one for the extra power and torque put through it whilst towing a fully loaded trailer up a long hill in a heatwave.... ie, well over engineered....
15th Jul 2021 11:18am |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 2982 |
That was my thought too... However, I've read if the firmware in the TCM needs flashed to make this box work with my car then the adaptions are reset as part of that process which is a bit worrying given what happened to the last box 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather 2007 Range Rover Supercharged in Java Black with Ivory Leather 2012 Range Rover 5.0 SC Autobiography in Indus Silver with Jet/Ivory Interior 2012 Range Rover 4.4 TDV8 Autobiography in Baltic Blue with Sand Interior |
15th Jul 2021 11:25am |
Yeah... if you can't help doing it, so be it, but if you have the option...!! Pete
15th Jul 2021 11:54am |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 911 |
The Disco 3 (220kW/427Nm) 069 transmission has a lower torque/power capacity than the RRS (287kW/550Nm) 070 unit.
15th Jul 2021 2:14pm |
Thanks Phil.
15th Jul 2021 2:26pm |
Sorry if I've missed this, but what exactly is wrong with your 070 transmission?
15th Jul 2021 5:36pm |
Phil,
15th Jul 2021 9:06pm |
When I bought my car in January this year it was delivered to me sight unseen due to COVID. When I drove it initially and it went to change from 2nd to 3rd it banged into gear.
15th Jul 2021 11:55pm |
As both the 069 & 070 transmissions use the identical Mechatronic unit (1068 198 942) the electronic module from your 070 could be swapped with the 069 one to avoid it having to be paired with your vehicle. Just to be clear, I talking about just the electronic module
16th Jul 2021 12:33am |
Thanks for your input once again, Phil.
16th Jul 2021 1:15am |
By all means send me your 070 transmission & I will strip it and report back on what has caused the failure. I can also price up everything you will need to rebuild it to get it back to 100% and you could then make the decision what you want to do with it. I can supply you with all the parts if you want to have a go yourself – it’s really very straightforward.
17th Jul 2021 3:04pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16171 |
Forgive the off topic question please
18th Jul 2021 12:30am |
(Sorry everyone)
18th Jul 2021 2:15pm |
I finished fitting the new transmission tonight and reconnected the battery.
20th Jul 2021 11:07pm |
