![]() | Home > Maintenance & Mods (L322) > Rust prevention etc |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822
Just do a search for "Rust" loads of suggestions... Personally I like Dinitrol...
| oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 397
hi i would go for vht for exhaust parts . and for the rest rub down paintwork or key it and then mix some epoxy resin and paint on then light key next day and go over the top finish coat with your hammerite black no more rust as no moist or salt can get past the epoxy resin coat new vehicle purchase
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3988
I paint all the underside vulnerable parts with grease every couple of years and spray the whole underside with engine oil every year. Result is no rust at all which is quite remarkable considering l live next to the beach and the car is subject to salt spray every winter.
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3883
First job I had done when I bought mine at 3/4 years old was to get all the plastic liners sills etc removed and then steamed cleaned and treated with Dinitrol.
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4351
Look at Lanoguard. New kid on block. Not tried it yet. Less mess than dinitrol Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
| stevepen Member Since: 03 Feb 2017 Location: Cheshire Posts: 64
I used Lanoguard. Brilliant stuff and easy to apply. 2011 Vogue SE TDV8 |
Does it weather well Steve? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
| ur20v Member Since: 19 Feb 2019 Location: None Posts: 634
Deleted |
| GustavW Member Since: 26 May 2021 Location: Kalmar Posts: 42
Thanks for the replies!
| NobbyC Member Since: 29 Dec 2015 Location: Princes Risborough Posts: 125
I used Aquaseal when I rebuilt my 1963 series 2 and it remained until I sold it on rust free for the next 10years without further treatment despite all lot of abuse in all conditions. Developed for salty environments so may be worth a punt. https://aquasteel.co.uk/ |
Deleted |
| AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464
Definite vote for aquasteel here, I used to work offshore on vessels and platforms, the ONLY antirust / rust treatment that worked was aquasteel. The most hostile of environments (typically hydraulic pipework on our winch launch and recovery for an ROV), constantly exposed to salt spray, baking in the sun etc. Aquasteel literally apply and forget, it's brilliant. BMW i3 Electric Car
Not sure yet. Only did it about 5 months ago. Still looks like the day I put on at the moment but a winter will be the test. They do say it will need redoing but as it's so easy and quick to do that's not a problem. 2011 Vogue SE TDV8 |
Aquaseal seems very promising, however it seems hard to come by here in Sweden.
