Home > Maintenance & Mods (L322) > Rust prevention etc
GustavW
Sweden
Rust prevention etc
Hi there,
What do you guys do to prevent rust on sensitive spots?
I've been thinking about painting the exhaust (mainly because of all the stone chips over the years), tow hook etc with black hammerite and maybe also on other spots. Is this a good idea or what have you done to yours?
I live in Sweden with salty winters...the climate here is great for rust and the L322 2011 tdv8 (4.4) clearly needs help to cope in these conditions.
Any ideas/suggestions are much appreciated. Its summer now, but soon enough winters coming Wink
Cheers
Gus Fuji White 2011, 4.4 TDV8 Vogue SE
Post #600789 15th Jul 2021 8:52pm
Just do a search for "Rust" loads of suggestions... Personally I like Dinitrol...
https://www.dinitroldirect.com/ Pete
-Click here for Thread-
Post #600797 15th Jul 2021 9:12pm
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
hi i would go for vht for exhaust parts . and for the rest rub down paintwork or key it and then mix some epoxy resin and paint on then light key next day and go over the top finish coat with your hammerite black no more rust as no moist or salt can get past the epoxy resin coat new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #600798 15th Jul 2021 9:13pm
I paint all the underside vulnerable parts with grease every couple of years and spray the whole underside with engine oil every year. Result is no rust at all which is quite remarkable considering l live next to the beach and the car is subject to salt spray every winter.
I don’t think you need to paint the exhaust, mine is 17 years old and still sound even though it looks slightly corroded.
Post #600812 15th Jul 2021 10:31pm
Baltic Blue
First job I had done when I bought mine at 3/4 years old was to get all the plastic liners sills etc removed and then steamed cleaned and treated with Dinitrol.
6/7 years later and it stil looks like new underneath.
Not cheap, but a good long term investment because it was always going to be a keeper.
Post #600833 16th Jul 2021 7:53am
DrRob
Look at Lanoguard. New kid on block. Not tried it yet. Less mess than dinitrol Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #600836 16th Jul 2021 8:22am
stevepen
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Stornoway Grey
I used Lanoguard. Brilliant stuff and easy to apply. 2011 Vogue SE TDV8
Post #600851 16th Jul 2021 11:00am
DrRob
Does it weather well Steve? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #600872 16th Jul 2021 2:42pm
ur20v
A Trap
Deleted
Post #600874 16th Jul 2021 3:43pm
GustavW
Sweden
Thanks for the replies!
As of now I've emailed a bunch of shops looking to proper rust proof my car. A brush of Hammerite is all good probably but no comparison to a full treatment...
Moving to Spain would be nice but they dont have moose burgers there so I'll stay here for the time being Very Happy
I reason that rust repairs are pricey, better spend some hard earned cash on preventative care and save some trouble.
Is Dinitrol the real deal? Is it as good as google says? Any firsthand experiences on your cars?
Cheers,
Post #600887 16th Jul 2021 7:16pm
NobbyC
United Kingdom 2005 Range Rover Vogue 4.4 V8 Buckingham Blue
I used Aquaseal when I rebuilt my 1963 series 2 and it remained until I sold it on rust free for the next 10years without further treatment despite all lot of abuse in all conditions. Developed for salty environments so may be worth a punt. https://aquasteel.co.uk/
Post #600891 16th Jul 2021 7:39pm
ur20v
A Trap
Deleted
Post #600913 17th Jul 2021 8:37am
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Definite vote for aquasteel here, I used to work offshore on vessels and platforms, the ONLY antirust / rust treatment that worked was aquasteel. The most hostile of environments (typically hydraulic pipework on our winch launch and recovery for an ROV), constantly exposed to salt spray, baking in the sun etc. Aquasteel literally apply and forget, it's brilliant. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #600928 17th Jul 2021 10:46am
stevepen
Not sure yet. Only did it about 5 months ago. Still looks like the day I put on at the moment but a winter will be the test. They do say it will need redoing but as it's so easy and quick to do that's not a problem. 2011 Vogue SE TDV8
Post #601024 18th Jul 2021 12:27pm
GustavW
Sweden
Aquaseal seems very promising, however it seems hard to come by here in Sweden.
I've called around at a few different Dinitrol centers and will probably do a full "rust check" and do whatever they recommend. I want to keep this car for a looong time.
Cheers for all the advice and suggestions Fuji White 2011, 4.4 TDV8 Vogue SE
Post #601166 19th Jul 2021 6:55pm
