Home > Maintenance & Mods (L322) > And now front brakes are on the list!!!
Ffrr-lover
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
I have brake squeal. It’s fine when the windows are up, but when you see pedestrians and other drivers turn, look and wince as you come to a stop you realise that despite the serenity in the cabin you need to do something about it.
So I decided to take the front wheels off and take a look (well, wheel… I didn’t make it to the other side!)
My plan was to take the pads out to check for copper slip, sticky stuff and other issues, as well as check over the pistons to see how they look… but can’t get the bloody pins out!
You can see where they’ve had a good hammering by someone at some point, and the end of the pin is also misshaped so I thought I’d leave it in place and order replacements before attempting those again!
You’ll also appreciate the paintwork too… clearly they were yellow at some point and have been painted over which is coming off and looks awful! I find it looks like rust and mould from a distance Rolling Eyes
I am now going to look at stripping and rebuilding them myself, or maybe use someone else to do it all for me.
https://www.bcs-automotive.co.uk/brake-cal.../#6pistons
According to their website these guys charge £78 per calliper and that include painting! Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #601000 18th Jul 2021 10:09am
TJH1985
I must have spent 15/20 minutes per pin yesterday on our L405, two dissimilar metals is never fun.
Ours were not in such bad shape, but even then I ended up cutting one in half that was just bending out.
I cleaned them up and then soaked them in a quick release fluid for a hour or so before, then with a good quality punch started to work them forwards and backwards until they were nice and free.
I also cleaned out all the holes of corrosion and coated in copper slip prior to assembling with new pins etc.
Probably the worst brake job I’ve ever done!
 Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #601003 18th Jul 2021 10:27am
DrRob
I’ve got this job to look forward to soon. Might start soaking the pins in plus gas...
I’ve got all new fitting kit alongside the pads and discs. Also bought new caliper bolts and the correct socket for them
Once again, Advanced Factors for me Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #601036 18th Jul 2021 1:21pm
Mikey
These 6 pots are becoming a right pain. The issue is the locking collar on the inside edge, stuck in place then the pin bends while trying to remove
I've had to drill and extract the pins in the past, they have been that tight...
Ceramic grease is essential when rebuilding, to prevent the pins seizing again in the future Thumbs Up
Post #601038 18th Jul 2021 1:43pm
ur20v
A Trap
Deleted
Post #601040 18th Jul 2021 2:01pm
TJH1985
Good shout on the copper slip, not sure why I always reach for it as it never touches the lotus.
On the subject of the lotus, that’s aluminium and steel all over the place, Lotus use duralac joint compound from the factory and you have absolutely no issues between the two metals. Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Post #601046 18th Jul 2021 3:09pm
ur20v
A Trap
Deleted
Post #601047 18th Jul 2021 4:18pm
Ffrr-lover
Cheers for the posts guys. I have a pot of copper slip, but will now get something more suitable such as duralac or permatex. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #601062 18th Jul 2021 8:01pm
