![]() | Home > My Range Rover > Big Blue V8 Story |
| Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929
Good point that. Never even occurred too me so think I'll drill two holes and pop rivet a metal plate on the bottom and top of it |
| Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601
that is what most people do!! i did that on my old TD6 2012 Vogue 4.4 TDV8 - Current
Sounds like an easier way of doing it tbh so that's the next task for me soon as the snow vacates |
So had a look at the brakes yesterday as I originally suspected the rear guards was knackered with all the screeching. Nope the push pins had both fallen out and stuck behind the disc so rectified that minor issue now I suspect the water pump is leaking as it appears quite wet behind the pump and it's dripping a bit so off too order one of them shortly. While under the bonnet decided to have a look at why one latch was holding the bonnet down. Turns out the clip inside the lock wasn't springing out and locking the bonnet down so wd40 and a flat head resolved that issue.
Still going then?
Cheers mate. Yea I'll keep it running till its not cost efficient in parts too replace but wear n tear never bothers me. It's on 162k now but I was going Essex to county Durham 4 times a month a while ago so already had a good run.
Bad water leak appears to have arrived on the v8 and going through maybe 5 litres of water every 6 days.
Whoops. Ripped the abs sensor off and damaged the splash guard. Guess I know what I'm doing on my days off at the weekend. Other then that car seems to be running good still.
So early finish from work today so cracked on with this sensor... only took two hours to sort it. Hour of that was spent trying to get the wheel off as it had seized its self to the hub.... soon as it was off decided no point being gentle with the old sensor so smash the top part off then git the drill out and a pair of pliers. 20 mins later hey presto it's off, bit of a tidy up on the outside and the inside followed by some gentle persuasion on popping it in and its all sorted. Clear it off on gap and it's sorted...
| Clabs Member Since: 08 Mar 2017 Location: Watford, Herts Posts: 125
Loving your updates mate and glad you are still showing the old girl some love |
Cheers clabs. Yea range gets some love now and then although the owner could do with some as well....
Sooooo the water leak returns so done a bit of investigation and you can see there is evidence of a water leak at the front of the valley pan gasket. Pretty sure it ain't that as I done this a while ago so decided to order a new pump just in case. Finally a day off from work so time to investigate. Turns out the previous person who done the pump didn't fit a gasket so thought what the hell might as well get it changed anyways. Took the car in for tracking and now gotta get the rear arms changed as well now oh the joy π π. Other then that decided that I should spend my weeks earnings on two items for the subaru.
Well I think that's the end of the pully
https://youtube.com/shorts/lmA3KXLuPOM?feature=share
